After the debacle in El Dorado, I need to fabricate a new fuselage for the profile Oriental. There are serious issues at the doublers and getting rid of the existing fuselage will let me look at the wing closely. The wing actually looks structurally sound. A new fuselage will also be shorter at the nose to allow removing some tail weight.The question: what density balsa should I be looking at? Bear in mind, the plane is a learning tool. I'm guessing 8-9 lb wood.
Hey DanYour guess at wood weight sounds pretty good to me. Built-up profile fuselages are great if you don't crash them, but kinda hard to repair if you do (assuming you don't crash them thoroughly, which is what it sounds like you did).
