  • July 19, 2025, 01:46:22 AM
Author Topic: tip weight box  (Read 1463 times)
Offline Bootlegger
tip weight box
« on: September 17, 2018, 09:30:29 AM »
  Does anyone have a drawing/diagram of a tip weight box that they can share on the Hanger?  Thanks a lot..
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: tip weight box
« Reply #1 on: September 17, 2018, 09:43:49 AM »
http://www.flyinglines.org/Shop%20Tips.html
The wonders of Google:
Offline RC Storick
Re: tip weight box
« Reply #2 on: September 17, 2018, 04:34:17 PM »
Offline Bill Ervin
Re: tip weight box
« Reply #3 on: September 17, 2018, 05:19:38 PM »
Here’s another style Gil.  Stolen from Ted.
Offline Bill Ervin
Re: tip weight box
« Reply #4 on: September 17, 2018, 05:23:19 PM »
Wingtip detail on the Imitation plans.
Offline frank williams
Offline Myron Firmin
Re: tip weight box
« Reply #6 on: September 17, 2018, 08:13:08 PM »
I found this drawing a while back . . . hope it helps.
Myron Firmin
Definition: Work Bench, a place to stack stuff, so you can build on the card table.
www.facebook.com/ringmastersflyingclub
Offline Bootlegger
Re: tip weight box
« Reply #7 on: September 18, 2018, 07:13:00 AM »
 Myron, I sent you a P/M..
Gil Causey
AMA# 6964
Offline Gary Dowler
Re: tip weight box
« Reply #8 on: September 18, 2018, 09:17:22 AM »
So is this just a nylon screw that plugs the hole? You fill it with lead shot?
Gary
Offline Bill Ervin
Re: tip weight box
« Reply #9 on: September 18, 2018, 09:47:41 AM »
Yes Gary, I’ll probably try regular BB’s first cause they’re less messy.  The cavity was made large enough that the needed weight should be reached without having to resort to lead.
Offline Gary Dowler
Re: tip weight box
« Reply #10 on: September 18, 2018, 10:04:40 AM »
Great idea.  Hope you don't mind, but I plan to steal it for my project I plan to build next year.  Its neat and clean and I like it!
Gary
Re: tip weight box
« Reply #11 on: September 19, 2018, 12:52:41 PM »
I used to buy those ply tip weight boxes, and glue them all together.  Lately, I have simply used a scrap block of balsa, about 1" square.  Drill a 1/2" hole partly through and glue it in the wing.  Finish with a ply cover.  It holds some .45 caliber lead balls from my muzzleloader rifle.  I can add or remove the lead.  Simple, fast, and no cost.
Floyd.
