Getting Tangental , ( a Branch Line ! ) THIS flogged frome Jose , scaled to 16 inch hinge to hinge , gives 2 in spinner & wheels ( if I recall wright ) .
Id use 60 in span , with as above , for somthing approprite to weight , in the nose . ( ST 46 , FP40 , LA 46 & within 5 either way of 45 Oz , with Fuse Mtd Gear )( or of 55 ! )
Nailing a plank or a stick or two ( bearers ) thinking in profiles a hard say 1 x 1/2 in , wing top to empenage , the rest as you will ( hollow / 2 lb
wood , or whatever )
for torsional ridgidity / location . tho theres always 1/2 x 3/8 carbon tube yacht sail battens ! . A bit of artistic liscence , 7 kick it in the guts, trev . ( That Means ' get it over & Done )
And You Too , could be a master of style, discernment , discrimination ( this used to mean you knew which way was up , drove a ( real ) Aston Martin , and were mistaken
for James Bond on occasion . or Billy Bishop etc . )This otherwise means use your own crayons & pencils in places . Both LJ & Time Machine being PATTERNMASTER Derived .
Dr Who , Tardis - Time Machine , etc . unless you prefer the H G Wells device .
Did Someone Mention a 50 ?? say 45 to 60 Oz should be feasable .
