  • June 29, 2025, 12:32:51 PM
Author Topic: Venturi's OS engines  (Read 1070 times)
Online Paul Taylor
« on: May 29, 2010, 12:31:48 PM »
I am now ready to try my hand at making a few Venturi's.
I have a few questions about sizes. I have a OS Max-S 30 and a OS Max -25 (it does not say FP on the case). I have searched the OS web site under engine parts old and new and I can not find any information on them.
Anyone know what size the hold needs to be and how long to make them?
I have one for a FP 20-25. Will that work in the engines above?
Any info would be helpful.
Offline Bill Adair
  • AMA 182626
Re: Venturi's OS engines
« Reply #1 on: May 29, 2010, 12:58:26 PM »
Paul,
I have a venturi for the 25 FP, but I don't think that will work, since the FP is a higher performance engine. Someone here must have one they can measure for you. Was just leaving for the field, and will check back when I return.
My 25 FP-S venturi is .260" ID, and projects about .446" above the case opening, but I don't know if the 25 came with two venturi, like the 40 FP-S.
Also have a 35 S that should be pretty close, and will measure that for you when I get home, if you don't get an answer here first.
Offline Bill Gruby
« Reply #2 on: May 29, 2010, 01:01:28 PM »
 Go to this site Paul. Find the Design board in the left column. Go there and you will find more info than you need at this point on Custom Venturis.
 http://www.clacro.de/index.htm
 "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Online Paul Taylor
« Reply #3 on: May 29, 2010, 01:10:27 PM »
Thanks Bill and Bill.
I will try the link. Stay tooned cause I am sure I will have more silly questions. y1
« Reply #4 on: May 29, 2010, 04:38:56 PM »
There is no silly, stupid, dumb or what ever other adjetive you can use for a question until after the fact that you should have asked the question before hand before asking the question.  Now what was the question? n~
