  • July 31, 2025, 04:27:20 PM
Author Topic: Thunder Gazer cowl  (Read 3154 times)
Offline tom brightbill
Thunder Gazer cowl
« on: March 03, 2015, 09:04:53 PM »
Does anyone have any pictures of the T/G cowl?  The plans only show a side view with no detail other than the attachment tabs. Hmm.....
Tom
AMA 34849
Re: Thunder Gazer cowl
« Reply #1 on: March 03, 2015, 09:43:57 PM »
   Let me dig around, I am sure I have some, probably inflight, but pretty good (thanks to Nikon and 1/4000 second shutters).
p.s. try this one (lightened to show the shape a little better).
Offline Brian Massey
    • California Car Clubs
« Reply #2 on: March 04, 2015, 11:33:32 AM »
I read the title as "thunder Gazer cow!" (cow with an exclamation point). I wondered "what the h*ll?"
Brian
AMA 55421
Madera, CA
« Reply #3 on: March 04, 2015, 11:44:07 AM »
 The "Thunder Gazer Cow" is a side project of the West Coast Sekrit Kabal. David did such a good job designing the airplane that we transferred him to our extensive genetic engineering division.  But don't talk about that in public!
« Reply #4 on: March 04, 2015, 12:36:43 PM »
Thanks Brett, anything additional will also be appreciated.
Brian, maybe you have planted the seed of a paint scheme (sorry Dave !) 😁
AMA 34849
« Reply #5 on: March 04, 2015, 02:52:20 PM »
How udderly exciting for Dave!
Brian
AMA 55421
Madera, CA
« Reply #6 on: March 04, 2015, 02:58:12 PM »
If you do, you should see if Chick Fil A will sponsor you!  #^
Brian
AMA 55421
Madera, CA
« Reply #7 on: March 04, 2015, 06:49:20 PM »
   I am sorry, but details of our unnatural gene splicing, genetic experimentation, or the ape-human hybrid projects is strictly need-to-know.
« Reply #8 on: March 04, 2015, 07:58:25 PM »
Thunder Gurnsey?
« Reply #9 on: March 04, 2015, 08:24:14 PM »
Thunder Gurnsey?
   DING DING DING DING!!!! Da Winna! y1 y1 LL~
Offline PerttiMe
« Reply #10 on: March 05, 2015, 09:55:23 AM »
I doubt there are two identical Thunder Gazer cols: they are mainly hand made by individualists ;)
This thread has some photos that might help:
http://stunthanger.com/smf/index.php/topic,34368.0.html
Online Matt Colan
« Reply #11 on: March 06, 2015, 09:03:50 AM »
Here's a couple pictures of my Thundergazer looking at the cowl. Hope this helps!
« Reply #12 on: March 06, 2015, 05:21:07 PM »
Thanks Matt, it certainly does.
AMA 34849
Offline Shawn Lenci
« Reply #13 on: March 06, 2015, 05:30:37 PM »
Tom...Just put a big ole hole in the front so air can get to the engine and another hole for it to get out! ;D
Shawn
AMA 97686
« Reply #14 on: March 07, 2015, 09:12:10 AM »
Remember, exit hole should be bigger.
« Reply #15 on: March 07, 2015, 09:15:26 AM »
  Remember, the exit hole should not exist. Or at least, not in the cowl.
     If you put almost any air exhausts in the cowl, before about the coupler, the front end of the pipe will very likely melt. The air should come in the front, and exit only around the pipe tunnel. Air needs to come in the front and flow over the pipe, DO NOT put any outlets ahead of the coupler. Same with a fully enclosed pipe, the air cannot exit before the end.
   In Dave's case, the coupler is out in the breeze right under the fuel tank, but there are effectively no outlets in the cowl.
Offline Larry Fernandez
« Reply #16 on: March 07, 2015, 12:31:28 PM »
I know that the gene splicing experiments were to be kept under wraps, but don't you find it somewhat suspicious that Dave so eagerly volunteered?
I cant help but thinking that Dave has other motives in mind here. A couple of years ago he said something about what it might take to get
possession of Walter Johnson or Warren Spahn's DNA.
Knowing the way Dave has always tried to bend and twist the rules of the "Hurl" and as smart as Dave is, I think our friend is up to no good.
Just something for the "Hurl Committee to start thinking about.
Larry, Buttafucco Stunt Team
« Reply #17 on: March 07, 2015, 07:46:43 PM »
Brett, thanks for that important detail.
It will be a bit (sometime this spring) I think for completion. It's going to have a two piece wing, and three piece fuse (tail feathers removable like Mike Haverly's Sultan, and a separation behind the trailing edge similar to one of Kaz's Blue Max's. All this is so that it can be transported in a box on my bike (Triumph type).
I just hope Dave F. isn't going to be offended by the paint scheme.
AMA 34849
