The reason for the original post – the control line community should have the right under the rules to utilize and develop any new technology as long as it does not interfere with any other event. Recent rule changes resulted in needless restrictions on the new 2.4Ghz Spektrum radio equipment usage in control line. There appears to be no set to set interference problem with this technology. I do plan to sponsor a rules change to allow Spectrum type devices and look at a rewording to clearly allow infrared. Infrared should be allowable under this rule. Possible interference with another infrared controlled model on the field is a contest management problem – not a rules problem.
I fully agree with the sanctity of the manual control of up and down through the lines, but all else should be open to development. Something like 2.4Ghz Spektrum RC equipment opens up several possibilities for auxiliary controls in control line stunt, scale and carrier.
I do not agree with the “traditional” - auxiliary control thru the lines only argument. I have been a control liner since 1946. “Line control only” was never a valid reason, in my consideration, to limit auxiliary controls. It was sponsored way back by the RC groups, with good cause, to prevent overwhelming of frequencies. The restriction did not come from the control line side.
Bob Machado developed a successful tethered control line profile on a single line a couple of years ago that was completely radio controlled from outside the circle – He had up/down, flaperons and rudder as well as throttle. An interesting experiment, but not control line. While it was completely illegal it showed what can be done but it lost the main element - the feel of the airplane.
Current thru the lines auxiliary control systems are pretty much custom made, most are cumbersome, unreliable and not readily available. I started with insulated lines back in the 50’s motivated by Lou Andrews and his special event wins at the Plymouth Internationals using throttle. I flew throttle stunt some back in the late 50’s – after a lot of practice it settled into: full throttle for the wing over, power down for the round loops and inverted, power up a little for squares and triangles, power up for verticals and overheads. It worked but the insulated lines were a pain, they made it not worth the effort. Lou Andrews often said there has to be a better way of getting auxiliary control to the model other than the lines. Here it is, Spektrum, 50 years later.
Control line is not a dinosaur or relic that needs to be “preserved”. It is a viable and still developing sport and we should not put restrictions on it. We have enough “nostalgia” events to preserve things for the traditionalists.
Should we have outlawed - glow plugs, flaps, uniflow tanks, tuned pipes, fiberglass, epoxy, hot stuff, monokote, carbon fiber, foam wings and above all ARF’s? The main point is new ideas and equipment come along all the time and this is one that our people should be able to use if they want to without arbitrary rule problems.
Dave Cook
