  • July 17, 2025, 11:36:06 PM
Author Topic: Thinning epoxy  (Read 8294 times)
Offline Robert Zambelli
Thinning epoxy
« on: September 16, 2010, 03:16:53 PM »
Maybe this was discussed here before but here goes.
I have used brushed on Finish Coat epoxy with good results.
Has anyone ever thinned it to a spray consistency?
Results?
THANKS, Bob Z.
« Last Edit: September 16, 2010, 11:09:04 PM by Robert Zambelli »
Re: Thiining epoxy
« Reply #1 on: September 16, 2010, 03:20:51 PM »
WHY????  If it is for a finish, just go get some Klas-Kote Clear.   H^^
Re: Thiining epoxy
« Reply #2 on: September 16, 2010, 03:38:03 PM »
I thin epoxy glue to brush consistency to fuel-proof engine compartments and whatnot.
Use 99% isopropyl alcohol, and let us know if it's a good cheapskate way to spray epoxy!
(Watch the mist, though -- epoxy is way toxic, in a sneaky cumulative sort of way.  Ever since developing a sensitivity to CA I've worn gloves with epoxy.  I don't want to lose another glue I can use with impunity, and I don't want my doctor telling me I can't build model airplanes any more).
Offline Neville Legg
Re: Thiining epoxy
« Reply #3 on: September 16, 2010, 03:51:15 PM »
You can use pure Methanol to thin epoxy!
Cheers    Neville
(not) Descartes
Re: Thinning epoxy
« Reply #4 on: September 26, 2010, 02:54:51 PM »
Gentlemen: Thanks for the advice. I used methanol and it worked perfectly.
I used it to refinish my steering wheel.
Check the results!
Offline sleepy gomez
Re: Thinning epoxy
« Reply #5 on: September 26, 2010, 07:55:34 PM »
A few years ago when I was the Technical Editor/writer at Stock Car Racing magazine I wrote an article about using J-B Weld (an epoxy) in a puncture type radiator repair.  I used denatured (no water) alcohol to thin the J-B Weld.  The company didn't know that alcohol could be used to thin their product.  They sent me a care package containing all of the products they made!  Seven years later and I'm still using out of that care package.  Good people, good products.
Dwayne
Re: Thinning epoxy
« Reply #6 on: September 26, 2010, 09:06:39 PM »
I used to read that mag almost religously, is it still being puplished?
Offline Mike Anderson
Re: Thinning epoxy
« Reply #7 on: September 26, 2010, 10:49:47 PM »
.....  I used denatured (no water) alcohol to thin the J-B Weld.  ....
I think you mean the medical grade isopropyl which is over 90% pure (where the 'common' isopropyl is 75 to 80 %).
'Denatured' is ethanol with enough methanol added to make it poisonous.
I've actually used all three to thin epoxy at various times - it doesn't seem to matter much to the epoxy.
Mike@   AMA 10086
Central Iowa
Re: Thinning epoxy
« Reply #8 on: September 27, 2010, 08:44:20 AM »
Check the results!
Now do you have a new pair of drivers gloves for that?  Don't want greasy fringer prints all over it. LL~ LL~ LL~
Re: Thinning epoxy
« Reply #9 on: September 27, 2010, 12:10:22 PM »
Answer to sleepy.  I used JB Weld to repair a radiator on my Toyota.  The seam on the top opened up, and JB Weld saved me $100 for a new radiator!  Floyd
Offline Hoss Cain
Re: Thiining epoxy
« Reply #10 on: September 27, 2010, 10:26:07 PM »
For that kind of thinning, try mixing whatever type epoxy you want, then take your "money"-kote heatgun or a good hairdrier or any heat gun, and heat it up. The epoxy will turn Gin-Thin and run all over. Some cheap brushes and tou can fuel proof large areas very quickly. keep it warm as soon as it begans to cool, it will start setting regardless of the time for the specific epoxy. Slower setting epoxy may take some time to lose all the sticky but it quickly will stop running when the heat is removed.
Horrace Cain
AMA L-93 CD and Leader
Re: Thinning epoxy
« Reply #11 on: September 28, 2010, 08:51:20 PM »
To Dwayne post #6:  I couldn't make the PM work so I am answering here.  No SCR is no longer being published.  I left almost 3 years ago, ok I was canned.  Two years later they ceased publication.  They specifically did not want to do an online magazine.  So I started my own, underfunded and possibly ahead of my time.  Management didn't like that.  Oval Track Digest lasted just over a year.  I still write monthly articles for www.theracersresource.com  and a weekly tech column in Area Auto Racing News.  .
Re: Thinning epoxy
« Reply #12 on: September 29, 2010, 08:20:28 AM »
The rag that replaced "Stock Car Racing" is just too technical.  May let subxcription lapse as I don't race myself, but, love watching the guys/gals on the dirt 1/2 mile.   H^^
Offline don Burke
Re: Thinning epoxy
« Reply #13 on: September 29, 2010, 10:00:07 AM »
Agree with you on 1/2 mi dirt tracks!
I use WEST systems epoxy, IMO it's the easiest to work with I've ever used.  Get the pros and cons on thinning epoxy here:
http://www.seqair.com/skunkworks/Glues/WestSystem/Thinning/Thinning.html
don Burke AMA 843
Menifee, CA
Offline mike hartung
  • aeronut
Re: Thinning epoxy
« Reply #14 on: September 29, 2010, 11:24:42 AM »
Don, that was very interesting read about epoxy, thanks for the link.
blue skys and tail winds to all.
