Hi All,
I have a simple question, is Sig thinner compatable with Brodak paint?
Peter Mick
AMA 9581
Unfortunately is it not that simple. SIG thinner either works or doesn't work with different batches of Brodak. I ran into this with the clear on the last airplane, it worked fine with one can, then I switched, and when I went to thin it, it clotted up like transparent cottage cheese. The older can of Brodak thinner also wouldn't work, and a much later can did. Fortunately I found all this before it got on the airplane, unfortunately, I used an older can of clear that would thin properly - and it shrunk everything tremendously.
I have heard of people having the same issue with SIG and batch-to-batch incompatibility.
Probably, if it looks like it thins and mixes properly, it is
probably OK to use. For my money I am going to get a bunch of SIG Lite-Coat and thinner and use that and nothing else.
