Hi,
I believe Bootleggers actual need is a stand to help with field repairs so I will
try to help with that. Dave Hemstrought came up with the simpliest and best
field stand I have seen. It is a rectangle of .75" PVC pipe that is about 24" wide, about 30" long and about 20"-24" high. The way it is constructed is:
1. Each side is each side is glued together
2. the 4 cross pieces that create the width are held in with bolts and wing
nuts. the Top cross piece uses angle connectors and very short piece of
pipe to create a drop down section in order to clear the fuselage in the
center of the cross piece.
3. cover the top sides where the wing will rest and the drop down section
where the fuselage will rest with plasctic foam or rubber pipe insulator.
Parts list:(1) 4- .75" pipe side pieces pieces.
(2) 4- "PVC corner adapters" - adapter has 2 connectors at right
angles and 1 going down.
(3) 4- .75 PVC cross pieces with bolts and wingnuts- 4 angle
adapters for drop down section.
(4) 4- pieces foam pipe cover
Dave has a folding stool and I think he set the height of the stand so it would be comfortable for him to sit on his stool and work on his plane while it is upside down on the stand. I don't have any pictures of Daves stand so I can't help there.
So, Bootlegger you remove 4 wingnuts and pull the bolts it knocks down for easy transport which is what I think you were asking for. It is such a simple
and inexpensive design that it could be adapted to hold the plane upright to adjust a Rabe-rudder by providing clearance for LG or to create a different stand for a bigger fuselage for a semi-scale stunter.
Hope this helps,
Pat Robinson
