  • July 13, 2025, 07:42:07 PM
Author Topic: The Weather  (Read 8596 times)
Re: The Weather
« Reply #50 on: January 08, 2008, 02:15:26 PM »
Hi Mark,
I see we came up with similar yet dissimilar theories at approximately the same time.  I am believeing more, and more, that the Airions can build up in the pilot of time, and can be successfully transmitted, during flight, to the model, thereby displacing the Groundions present.  Might could explain why Keith's and Billy's planes (among others) seem to never age over hundreds and thousands of flights........ ?? ?? ??  I am seeing a direct correlation between the pilot, his abilities (both native and trained) and the amount of successful airtime each has had as it compares to his or her ability to transmit said Airions to the model in flight.
« Last Edit: January 08, 2008, 02:37:55 PM by Bill Little »
Re: The Weather
« Reply #51 on: January 08, 2008, 02:21:48 PM »
 ~^ '' ??? :o :o ??? ??? ??? ??? ??? Z@@ZZZ Z@@ZZZ Z@@ZZZ %^@ %^@ %^@ %^@ n~ n~ n~ n~ n~ n~ n~ n~ n~
Will
Offline don Burke
Re: The Weather
« Reply #52 on: January 08, 2008, 03:26:49 PM »
In reality the addition of Airions and Excellons occurs during both the building process and possibly a larger part during the practice process.  The actual addition is accomplished in the building process through use of the catalysts, sandpaper and elbow grease.  The elbow grease being the most important factor in getting those particular components to stick.
don Burke AMA 843
Menifee, CA
Offline Garf
    • Hangar Flying
Re: The Weather
« Reply #53 on: January 09, 2008, 08:42:57 AM »
WTF????????????????????
