Try a small FP venturi.
But that really defeats the whole purpose. You will cut your power by doing this. You will limit air intake which limits fuel intake which reduces power. You were saying you need to go up in Nitro for power.
Another thing you could try, if you havent already, is a Bru-line airfilter. The green filter will reduce the venturi size a little, less than going down to the 25 size, as it is a thicker foam. If you dont have a bru-line filter or cant locate one an o-ring and some layers of pantyhose will also do the trick plus you can tune to the exact size you need by adding and removing layers to complete the pattern and no more.
You could always try the old school trick of sticking a piece of balsa in one side of the ventrui between spraybar and the venturi wall. I have seen many guys do this when taming an FP 40 for a smaller plane. It lookes funny with a pice of balsa hagning out the ventrui. But it works every time.
You can try it a flight or and see the reduction in power and see if the added nitro will make up for the reduced venturi size.
The hotter it is the less dense the air is your mileage will go up as well. Have you tried the 10% nitro in your area now that the heat is here to stay? If so where in the pattern do you run out?
The added cap full of coleman Lantern fuel to one full gallon of glow fuel really works. Bob Gieseke turned me onto that trick when I was running out early one year and couldnt get a bigger tank in the plane.
