  • June 27, 2025, 07:49:58 AM
Author Topic: 1/2 A Pathfinder photos.  (Read 6782 times)
Offline jim gilmore
« on: September 24, 2009, 07:47:00 AM »
ok,here's the first photo I've taken.
Re: 1/2 A Pathfinder photos.
« Reply #1 on: September 24, 2009, 11:00:15 PM »
What engine do you have there?
Mongo
Offline jim gilmore
« Reply #2 on: September 25, 2009, 06:19:20 AM »
Thats a thunder tiger .10.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: September 25, 2009, 08:01:39 PM »
I thought calling an .061 a 1/2A was kinda pushing the envelope, but a .10???  Sorry, that's a solid "A" class.
What is the size of the plane you're putting it on? Surely not the little 1/2A Pathfinder?
--Ray
AMA902472
Offline Richard Grogan
« Reply #4 on: September 25, 2009, 09:16:34 PM »
Is this gonna be a racer???  ??? ::) ???
Long Live the CL Crowd!
                  AMA 85745
« Reply #5 on: September 26, 2009, 08:37:24 AM »
Some people say more power is better.  Have fun, DOC Holliday
« Reply #6 on: September 26, 2009, 08:59:48 AM »
The little PF has a 35" span and 234 squares - that makes it bigger than a Flying Clown, so the 10 is not oversize from that persepctive.  It has a fairly long nose so BALANCE could be an issue.
Jim, you might want to keep an eye on that...
Offline jim gilmore
« Reply #7 on: September 26, 2009, 10:51:36 AM »
True it is not a true 1/2A with a .10 on it. but then neither is a .061 a 1/2A a true 1/2 A.
It also is not a full PA stunt sized airplane. It's close to the .15 sized power of old.
I plan to mount the engine as far  aft as the space provides. I may when the time comes decide to mount the wing a little forward to lengthen the tail if necessary for balance. but so far little else seems necessary to me.
    • Minnesotamodeler
« Reply #8 on: September 26, 2009, 11:05:25 AM »
Well, you won't want for power, and that's a good thing...long lines, brother, long lines.
--Ray
AMA902472
Offline dennis lipsett
« Reply #9 on: September 26, 2009, 08:06:12 PM »
Your going to be suprised when you find out how long a run you get with a 1.5 oz tank and a 7/4 prop.
Dennis
Offline jim gilmore
« Reply #10 on: September 26, 2009, 10:00:38 PM »
i'm planning a 1 ounce tank.
Offline George
  • Love people, Use things.
« Reply #11 on: September 28, 2009, 07:24:54 AM »
Other than a possible balance problem, the TT .10 is a nice little engine.
George
George Bain
AMA 23454
Offline jim gilmore
« Reply #12 on: October 08, 2009, 11:00:00 AM »
Ok, things have been slow so here is where I an now.
Offline Andrew Borgogna
  • Andy
« Reply #13 on: October 08, 2009, 05:38:54 PM »
I too am builing a 1/2a Pathfinder.  I took a little different tact, I did  all the options to lighten up the plane and will be using an AP Wasp .061.  For what it's worth this is a very complex airplane, I lost count on the number of parts in the wing.  When you add in all the additional work to lignten the flaps, fuse, horizonal stab and elevators its quite a project.  I keep telling myself it just a profile, just a profile.......
Andy n~
Andrew B. Borgogna
Offline jim gilmore
« Reply #14 on: October 08, 2009, 09:10:09 PM »
Well you might notice i have not touched the tail or flaps yetr. I ran into the same problen as the shark 402. I was attempting to do the leadouts and found the leadout material is insufficent. I ran it from the bellcrank to the 2wingtip and bawck to the bellcrasnk and upon assemply it cannot possibly be cut to make it work. Unless itis expected to not run through the tubing 3 times it cannot be done as recommended by the ama.
Soooo I am on hold till I make my order for more stuff. So I'm prolly on hold till nov 1 st to make my order.... trying harder to create savings.
Offline Roger Vizioli
  • CLiner
« Reply #15 on: October 09, 2009, 01:04:18 PM »
Andy n~
Andy,
Yes, it is a profile. BUT - your efforts will be rewarded with a great flying model. Keep it light and have a ball.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
  • Andy
« Reply #16 on: October 10, 2009, 12:57:45 PM »
Thanks Roger, I am reaching the point where the thing looks like a plane.  I covered everything with Polyspan and clear dope.  I am working to keep it as light as possible.  I too almost got burned by the lead out material included in the kit.  Don't know what Brodak was thinking buy guys provide material that's long enough for the plane you pack it in.   ''  The die cutting on the ribs was darn near perfect, and the die cutting on the 1/32 plywood was very good, but the die cutting on the 1/16 plywood was die marking.  Making the nose ring was quite the project.  Brodak should give a prize to eveybody who  builds and completes a 1/2a Pathfinder.  Larry Renger sumed it up when he told me he opened up the box to one he bought then closed it and sold it.
Andy
Andrew B. Borgogna
Offline George
« Reply #17 on: October 10, 2009, 02:27:20 PM »
I remember years ago on one of the forums (Isky's, I think) a British fellow was comparing the way many US modelers build to the way many British modelers build and made the comment that his philosophy was, "Why use one piece when five will do?".
It was his notion that most Americans tend to simplify as much as possible, while he did not. I guess whether a plane takes too long to build depends on the builder.
I guess we could catagorize modelers as having more fun...building the plane, twiddling with the engine, flying the plane, or all of the above.  ;D
George
George Bain
AMA 23454
« Reply #18 on: October 12, 2009, 05:56:19 AM »
To all,  now you know why I buy in lthe bulk.  Like the leadouts,  I have had other kits other than Brodak in which the leadouts were not long enough.  Also this new generation needs one of the early kits which were printed wood.  We were in seventh heaven when die crunching came out.  Also I can remember SIG having some kits  in which some of the wood was printed.  Have fun,  DOC Holliday
Offline George
« Reply #19 on: October 12, 2009, 08:36:55 AM »
...Also this new generation needs one of the early kits which were printed wood...
...And also suffered through at least one Berkeley kit!   ::)
George
George Bain
AMA 23454
  • Andy
« Reply #20 on: October 12, 2009, 11:06:55 AM »
Hey Doc, I too built Comet kits and Berkley kits when I was a kid it was a true learning experiance to say the least.  As I have said many times "These are the good old days" of controline modeling.  Below are some pictures of my Pathfinder and the Norvell engine I plan to use until I switch to the AP Wasp.  The two engines are nearly identical.
Andy
Andrew B. Borgogna
Online Larry Renger
« Reply #21 on: October 12, 2009, 02:54:37 PM »
So I should start thinking of decals?
  • Andy
« Reply #22 on: October 13, 2009, 08:27:30 AM »
Larry
In a word yep!
Andy
Andrew B. Borgogna
