  • June 24, 2025, 06:19:45 PM
Author Topic: New Ride for 23  (Read 1945 times)
Offline Joseph Daly
New Ride for 23
« on: April 11, 2023, 07:29:17 PM »
Steven’s new ride for 2023, our first attempt at a composite plane. He liked the Axioma that he flew at the Worlds, so we decided to build one. It came out a few oz more then we wanted. I took it for a test session on Monday, as he was at school (Ha Ha). It has a lot of promise. Here are a few shots of it.
Offline C.T. Schaefer
Re: New Ride for 23
« Reply #1 on: April 12, 2023, 04:52:31 AM »
Pretty cool!  Look forward to seeing that one on the field.
Offline jose modesto
Re: New Ride for 23
« Reply #2 on: April 12, 2023, 09:44:42 AM »
Very nice. Can’t wait to finish mine
Jose modesto
Offline jfv
Re: New Ride for 23
« Reply #3 on: April 12, 2023, 10:04:34 AM »
Very nice!
Jim Vigani
Online Doug Moon
Re: New Ride for 23
« Reply #4 on: April 14, 2023, 03:58:00 PM »
Did yall make the molds from an Axioma?
Planes looks great!  Did you paint it in the mold or afterwards?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Joseph Daly
Re: New Ride for 23
« Reply #5 on: April 14, 2023, 07:53:48 PM »
Doug,
Made the wing molds from the Axioma. We borrowed a shark fuse mold from Orestes. Yes painted white in the molds.
Online Doug Moon
Re: New Ride for 23
« Reply #6 on: April 18, 2023, 07:23:05 AM »
Doug,
Very COOL!
Doug Moon
AMA 496454
Online Doug Moon
Re: New Ride for 23
« Reply #7 on: April 26, 2023, 10:06:03 AM »
I am curious, do you find that you run a way aft LO position and more forward CG as well???
Doug Moon
AMA 496454
Offline Joseph Daly
Re: New Ride for 23
« Reply #8 on: April 26, 2023, 05:43:08 PM »
Hey Doug,
On this design it seems to like a forward LO position. The CG is at about 18%.
Now I find with my High Voltage the LO position is pretty far back and the CG is 12 to 15%. So go figure???
Online Mike Alimov
Re: New Ride for 23
« Reply #9 on: April 28, 2023, 05:29:28 AM »
I'm curious, what all-up weight did you guys arrive at? Also, did you use balsa or foam as your core material?
I noticed that the choice of paint affects the weight a lot- Klasskote lays down much lighter than the Rustoleum primer. We need to compare notes at the Nats -- this will be the first time in history when all Seniors are sporting all composite planes.
Offline Joseph Daly
Re: New Ride for 23
« Reply #10 on: April 28, 2023, 11:25:00 AM »
Mike,
All up weight is 66oz. we used both balsa and foam!!! The fuse is wood as a core material. The wings and tail at foam skins. So a hybrid!
Offline Doug Moisuk
Re: New Ride for 23
« Reply #11 on: April 28, 2023, 06:01:43 PM »
My new ride.
Doug Moisuk
MAAC 3360L
