  • June 30, 2025, 03:19:54 AM
Author Topic: The next laser kits NEW SV-11  (Read 1641 times)
« on: April 05, 2018, 07:22:02 PM »
Hi All
The  NEW design  SV-11 will be in stock soon,  This is  the  same airplane as the  original, but I re-designed  it , a few years  back to take the larger motor , larger props, pipes  tanks  that many use now.
The original  Used a  ST 51  ST 60 and  piped 40s, Pilots  routinely install  61 , 65, 75, 77s  now days,
So its the  same span  60.5 in span  same  nose, the difference is  the  fuse is wider to accept larger pipes,
The tail moment is longer to balance larger heavier  power plants,
The stab is  wider, more sq in  to help start and stop  stabilize more power up front, the  fuse is longer at the rear, larger  rudder  etc.
If you have an interest  please let me know
These are very complete kit with  either  al. or  CF  gear,  hinges , wheels, heavy duty  ball link control system, tip weight box , line slider , laser cut ply and  balsa parts , pipe mount, hand select wood.
Re: The next laser kits NEW SV-11
« Reply #1 on: April 05, 2018, 07:40:33 PM »
I have more than an interest.  I want one!  When will they actually be available and can we get in line now!
« Reply #2 on: April 06, 2018, 10:37:51 AM »
H Randy
Of course  you can, I already have people placing orders,  just let me know  I will add  your  name
regards
« Reply #3 on: April 06, 2018, 11:50:01 PM »
Is this the ARF parts from China in kit form or something different.
NO , same airplane  but it is the  Laser kit that  I make here in the  U.S.   just like the
DREADNOUGHT KITs
Tempest ll kits
Intrepid XL kit
Classic Open C kit
NOVAR kit
Evolution kits
etc
they have  nothing to do with the Chinese  or  ARFs
« Reply #4 on: April 13, 2018, 01:37:21 PM »
The final test build and fits has been finished  and  kits are being  cut now, so these  will be  shipping  soon
These  are  NOT in stock and shipping  just yet, but we are cutting kits, and some will start going out in the coming weeks
I am taking  orders  for the  SV-11  Laser cut  KITS ..   That have nothing to do with the  Chinese  SV-11  ARFs   other than they have the same name.
