  • July 25, 2025, 01:12:09 AM
Author Topic: The History of "Taps"  (Read 2048 times)
Offline Steve Scott
« on: May 29, 2011, 10:29:32 AM »
Memorial Day is the day we pause to remember our fallen soldiers, marines, sailors and airmen. We've all heard the familiar strains of this somber bugle tune. I thought it appropriate to post this history of the tune, taken from the US Department of Veteran Affairs website.
The Story of Taps
The 24-note melancholy bugle call known as “taps” is thought to be a revision of a French bugle signal, called “tattoo,” that notified soldiers to cease an evening’s drinking and return to their garrisons. It was sounded an hour before the final bugle call to end the day by extinguishing fires and lights. The last five measures of the tattoo resemble taps.
The word “taps” is an alteration of the obsolete word “taptoo,” derived from the Dutch “taptoe.” Taptoe was the command — “Tap toe!” — to shut (“toe to”) the “tap” of a keg.
The revision that gave us present-day taps was made during America’s Civil War by Union Gen. Daniel Adams Butterfield, heading a brigade camped at Harrison Landing, Va., near Richmond. Up to that time, the U.S. Army’s infantry call to end the day was the French final call, “L’Extinction des feux.” Gen. Butterfield decided the “lights out” music was too formal to signal the day’s end. One day in July 1862 he recalled the tattoo music and hummed a version of it to an aide, who wrote it down in music. Butterfield then asked the brigade bugler, Oliver W. Norton, to play the notes and, after listening, lengthened and shortened them while keeping his original melody.
He ordered Norton to play this new call at the end of each day thereafter, instead of the regulation call. The music was heard and appreciated by other brigades, who asked for copies and adopted this bugle call. It was even adopted by Confederate buglers.
This music was made the official Army bugle call after the war, but not given the name “taps” until 1874.
The first time taps was played at a military funeral may also have been in Virginia soon after Butterfield composed it. Union Capt. John Tidball, head of an artillery battery, ordered it played for the burial of a cannoneer killed in action. Not wanting to reveal the battery’s position in the woods to the enemy nearby, Tidball substituted taps for the traditional three rifle volleys fired over the grave. Taps was played at the funeral of Confederate Gen. Stonewall Jackson 10 months after it was composed. Army infantry regulations by 1891 required taps to be played at military funeral ceremonies.
Taps now is played by the military at burial and memorial services, to accompany the lowering of the flag and to signal the “lights out” command at day’s end.
Re: The History of "Taps"
« Reply #1 on: May 30, 2011, 05:05:44 AM »
That was very interesting Steve. Thanks for posting.
« Reply #2 on: May 30, 2011, 10:59:46 AM »
The bugle is an example of a "natural horn".  That is simply a tapered tube with no valves.  It can resonate (produce stable musical notes) only on a few frequencies.  All bugle calls are based on the half-dozen or so natural notes available on a bugle.  In order to produce all 12 notes of the scale, plus their overtones, extra lengths of tubing are provided, with pneumatic valves arranged to slightly lengthen or shorten the overall air column.  This is called a trumpet.  All modern brass instruments, from trumpet, french horn, tuba have these extra lengths of tubing and valves.
Offline Shultzie
« Reply #3 on: May 30, 2011, 11:09:42 AM »
Here is my bugle...(my favorite Symphonique C)
Played taps early this morning at a local small memorial near Gig Harbor. I use this trumpet simply because it projects so beautifully with the most regal voicing when played softly.
Don Shultz
« Reply #4 on: June 01, 2011, 03:23:52 PM »
A "C" bugle?  Does that mean your TAPS notes are G1,C2. E2, and G2 ?
"Revelie" has the same notes.
Offline Shultzie
« Reply #5 on: June 02, 2011, 09:12:53 PM »
 ;D y1
My custom NYC Custom Callet Symphonique C horn uses  Jerome Callet's "Expandabore" .470 bore concept and because of this...I play TAPS with all three valves down. For some strange reason...this seems to add a special depth and resonance to the sound...almost a human timbre  to the voicing of a trumpet?  H^^
« Last Edit: June 02, 2011, 09:30:37 PM by Shultzie »
Don Shultz
Offline Greg L Bahrman
« Reply #6 on: June 02, 2011, 11:14:37 PM »
The conductor of the orchestra is Andre Rieu from Holland. The young lady, her trumpet and her rendition of TAPS presented here. Many of you may never have heard taps played in its entirety, for all of the men & women that have died for us to have the freedom we have in America.
http://www.flixxy.com/trumpet-solo-melissa-venema.htm
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #7 on: June 03, 2011, 07:45:10 AM »
 I never got to the level of the young lady before I gave up the trumpet(cornet actually).  But, why do I alway tear up and get bleary eyed when I hear that melody.   At least one young soldier on the internet will not have it played over/for him as he fought and killed 40 taliban soldiers.
Offline Brian Massey
    • California Car Clubs
« Reply #8 on: June 03, 2011, 12:41:00 PM »
You left out the "E Flat" French Horn which has a forth valve that was operated by the thumb. Yea, I played French Horn in HS band. Now everytime I hear "Pomp & Circumstance" I get teary eyed.  LL~ LL~ LL~
Brian
AMA 55421
Madera, CA
« Reply #9 on: June 03, 2011, 12:59:30 PM »
The French Horn is hard to play, but think of playing the pipe organ!  Both hands and both feet flailing about all at once!  Even takes an assistant to run the stops for you.
F.C.
Offline afml
« Reply #10 on: June 03, 2011, 03:56:40 PM »
"You left out the "E Flat" French Horn which has a forth valve that was operated by the thumb. Yea, I played French Horn in HS band. Now everytime I hear "Pomp & Circumstance" I get teary eyed.  Layingdown Layingdown Layingdown
Brian"
Sorry Brian...
 A "double French Horn" is keyed in B Flat and F.
There is however, an E Flat Alto Horn!
"Tight lines!" H^^
Wes
Wes Eakin
« Reply #11 on: June 03, 2011, 11:32:18 PM »
Brian"
Sorry Brian...
"Tight lines!" H^^
Wes
I have to admit, it's been a long looong time. It may be in fact the "double horn" where three valves control the flow of air in the single horn, which is tuned to F or less commonly, B♭, and has a fourth valve, usually operated by the thumb, which routes the air to one set of tubing tuned to F or the second set of tubing tuned to B♭. Then there are Triple horns with five valves, tuned in F, B♭, and a descant E♭ or F.  . . . are you confused yet? (I am.) The horn I played was a school issue unit, no thumb valve. But my Grandfather gave me his horn which has the thumb valve. I have since passed that on to my oldest son who also played French Horn in HS. I hope he still has it; haven't asked in a long time. My Grandfather was the Postmaster at Norwalk, CA, and served as the towns Orchestra Conductor (back when small towns had them) and scored much of their music. I used to fly on the local HS grounds in Norwalk back then. Like I said, it's been a loooooong time.
I still love the sound of the French Horn; it has such a wonderful tonal quality, and so melodic.
Anyway, there's no way your comment is of a "casual" nature, you must have some knowledge of horns (and have a better memory than me), so what did you play???
Brian
« Last Edit: June 04, 2011, 12:05:48 AM by Brian Massey »
AMA 55421
Madera, CA
Offline afml
« Reply #12 on: June 04, 2011, 12:07:53 AM »
"Anyway, I still love the sound of the French Horn; it has such a wonderful tonal quality, and so melodic."
AMEN to that! y1
"So what did you play???"
FRENCH HORN! Still do.....
However, yesterday I played the radio, last week I played the 8-track and the R-T-R.
Next Sunday I'll be playing the Kentucky Lap Dulcimer in Church.
Right now I'm playing a CD: The great "Antiphonal Music of GABRIELI".
Contains performances of the Philadelphia, Cleveland, New England, and CHICAGO Brass Ensembles with a little of E.Power Biggs for giggles.
Now back to STUNT! #^
"Tight lines!"
Wes
Wes Eakin
« Reply #13 on: June 04, 2011, 10:16:57 AM »
If you are in doubt about the qualities of the French Horn, listen to the Brahms Trio in E-flat (op. 40).  It will make you want to buy one and start practicing!
