  • July 13, 2025, 05:46:06 AM
Author Topic: EVERYONE READ! The first of the year approaches  (Read 861 times)
Offline RC Storick
« on: December 29, 2006, 11:20:21 PM »
The first of the year approaches and I have warned everyone about user names. You user name is your real first and last name. Once this is changed you can modify you Display name to whatever you want. But come the first of the year I will be sending out and changing user names, Be sure your email address is correct in your profile of you will miss your reactivation message and locked out until I get an email from you. This change only effects a few members but it does effect quite a few members that are active on a daily basis. Do not send me a message I will message you for your info.
This is mandatory under FCC rules.
modify your profile so your real name is in there I will fix the user names. I am coming around to check there are NO EXCEPTIONS!
« Last Edit: December 30, 2006, 10:04:57 AM by Robert Storick »
