  • July 06, 2025, 01:23:02 PM
Author Topic: The dog flies.  (Read 1865 times)
Offline Curare
The dog flies.
« on: October 13, 2013, 06:46:28 PM »
Well guys, I managed to finish the dog that I've been waxing lyrical about on here.
it's not perfect, but then again, it was never going to be with a stack of new construction techniques employed, but it should be enough to keep me airbone for a while.
For those with a keen eye, it's basically a shrunk Imitation with a different fin and fuselage, plank tail and foam cored wings.
Thanks to everyone who coaxed me through this one, if it wasn't for stunthangar I'd have never gotten this far.
Greg
Greg Kowalski
AUS 36694
Re: The dog flies.
« Reply #1 on: October 13, 2013, 06:56:10 PM »
Looks cool!
Got to ask about the rod on the LE. I assume it a tip weight?
Offline Curare
Re: The dog flies.
« Reply #2 on: October 13, 2013, 07:08:39 PM »
Yeah, it's a tip weight tube, stolen from Ted Fancher's Doctor.
The tube is crimped at one end, and epoxied into the wing, after that, I machine up a 'pitot tube' plug for the other end.
The tube is filled with split shot sinkers, and I can adjust the tip weight down to about 5 grams at a time. For the first few flights though it's pretty much full of shot:D
Greg Kowalski
AUS 36694
Offline Dan Bregar
  • Field Marshall
Re: The dog flies.
« Reply #3 on: October 14, 2013, 04:07:07 AM »
Very nice !  So what motor and prop are you running ?  :)
AMA 33676
Re: The dog flies.
« Reply #4 on: October 14, 2013, 01:24:43 PM »
I thought it was a pitot tube.
Offline Curare
Re: The dog flies.
« Reply #5 on: October 14, 2013, 06:28:05 PM »
At this stage it's ALLL cheap gear. a turnigy SK3 35-36 (1200kv) and a 10x5 reverse rotation prop.
First flights were conducted with a 3000 4s nanotech, but I think I'll probably have enough to do the pattern on a 2700mah.
Greg Kowalski
AUS 36694
Re: The dog flies.
« Reply #6 on: October 15, 2013, 07:22:54 PM »
I'm not an e-flier, but have been around them for quite awhile. It appears to me that having some extra battery capacity can be a plus. What gets you through the pattern this week may not get through the pattern all year around, or if you find a better propeller. Just sayin'.....  H^^ Steve
Offline Curare
Re: The dog flies.
« Reply #7 on: October 15, 2013, 08:44:00 PM »
Steve, yeah you're right, I'm experiencing that in F3A.
A light day I'll get away with a 5.0 pack, but on a windy day I'll fall out of the sky on the last maneuvre on a 5.0, so you bulk up on mAh!
Greg Kowalski
AUS 36694
Re: The dog flies.
« Reply #8 on: October 15, 2013, 10:40:07 PM »
I suspect that changing to a 2 or 3 oz heavier battery pack on a CL eStunter might make a huge difference that you wouldn't notice with an R/C model with a 6 oz heavier battery pack. I think most would be better off with a consistent weight and response. When we do a CG change or handle spacing change, we usually do that before the first flight of the day, to avoid negative altitude pullouts.  H^^ Steve
Offline Curare
Re: The dog flies.
« Reply #9 on: October 15, 2013, 10:43:51 PM »
yeah, for sure. At this stage though we're still trimming, so the flights are short, just in case something goes wrong.
They'll get longer, and I'll get a better idea of what capacity I need, and at this stage, even if I'm short, I'm not too stressed, as I'm a long way off competition ready.
Greg Kowalski
AUS 36694
