  • July 03, 2025, 08:06:19 PM
Author Topic: Who designed the Tutor II  (Read 2072 times)
« on: March 07, 2008, 09:10:09 AM »
I know the Tutor II came from the Tutor. But who came up with the idea for the Tut2?  And don't say Top Flite. n~
Paul  H^^
Offline Scott Jenkins
Re: Who designed the Tutor II
« Reply #1 on: March 07, 2008, 10:39:53 AM »
Paul,
I have an original kit and plans by Top Flite. I will look at the plans tonight and see if it says who dunit.
Thirty five or more years ago I started out wanting to fly stunt but after a miserable experience with a
Jr. Nobler. I turned to combat and racing to relieve some of that aggression problem is, I am still aggressive
when it comes to racing finally got a good pilot (in training).    f~ ~^
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
« Reply #2 on: March 07, 2008, 11:13:32 AM »
I kinda doubt the Tutor II was designed by the same fella who designed the original Tutor.  I cannot recall who designed the Tutor, but I believe it was one of our great C/L scale pilots/builders.  Charlie Bauer??????????
Offline richardhfcl
  • AMA 82448
« Reply #3 on: March 07, 2008, 12:21:20 PM »
Bill,
     Charlie Bauer gives the credit for designing the Tutor by Top Flite to one of his sons (Mathew, perhaps?), although I'm not totally certain.  I think that in idle conversation at the field the subject of the Tutor II came up.  As I recall, we were told that he didn't know who designed the Tutor II.
     Best regards,
     Di9ck Ferrell
Richard Ferrell
AMA 82448
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #4 on: March 07, 2008, 08:32:17 PM »
Did TopFlite just scale up the original plans?
If so,  would that be considered a redesign?
Idunno.    ::)
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
Offline Mike Lauerman
« Reply #5 on: March 09, 2008, 06:51:09 PM »
maybe just a 'scaleup'.
« Reply #6 on: March 10, 2008, 01:45:52 AM »
 As far as I know or as it appears to my eye, the original Tutor is basically a profile Gieseke Nobler. Take a look at the outlines, and compare the wing and see if you see the resemblance that I do.
  I do believe that Charlie Baur or his son did work for TopFlite, just not sure which for sure but I believe it was Charlie. Several conversations with him over the years leaves me with a vague memory of that.
   TopFlite (actually Great Planes) has a staff of in house designers and engineers, and some never get the credit for the planes or equipment that they design. Everything they do is the property of Great Planes. A freind of mine here in the St. Louis area worked for GP for a few years as one of their designers and gave me a little insight to the situation. My guess is that one of their in-house guys did some basic blow up of the out line of the original model, did a little bit of consulting with some one on the ins and outs of C/L stunt, then worked with the GP kt engineers and the ARF contractor in China on the construction.
   That's my 2 cents worth.
Offline Bob Furr
« Reply #7 on: March 10, 2008, 02:53:11 PM »
Interesting... hard to believe how quickly last years purchase can become this years collectable classic... I just took a look at the Tower website and the Tutor II has been discontinued as far as I can tell.   Guess they did not sell enough of them.  Too bad as the loss of even an ARF is a loss to CL in general.
Bob Furr
