  • June 18, 2025, 12:59:29 PM
Author Topic: NAA membership for WC  (Read 1502 times)
« on: July 10, 2024, 11:55:14 AM »
I got some direction from Bill Lee on obtaining an NAA license.
https://naa.aero/membership/fai-sporting-license-form/?membership=FAI+Sporting+License+only
This link will save you the digging I needed to do.  It will cost you $50.  It will enable you to act as a crew member if you are pressed into service at the WC.
Offline BillLee
Re: NAA membership for WC
« Reply #1 on: July 10, 2024, 03:43:31 PM »
This link will save you the digging I needed to do.  It will cost you $50.  It will enable you toact as a crew member if you are pressed into service at the WC.
Only if you are registered with the organizers. If you are not registered, you are welcome to be a spectator, but "pressed into service" will require registration with the team.
Bill Lee
AMA 20018
