  • June 13, 2025, 04:31:42 AM
Author Topic: The B-17  (Read 10502 times)
The B-17
« on: April 23, 2023, 09:31:20 PM »
 This just never gets old... ;D
Offline Gary Dowler
Re: The B-17
« Reply #1 on: April 23, 2023, 09:58:32 PM »
Its amazing what the right guy, a 6' wing and 4-15FP's can accomplish!
Gary
Re: The B-17
« Reply #2 on: April 23, 2023, 11:05:35 PM »
What’s there left to do after you’ve won every major stunt contest multiple times and then enter a 4 engine bomber in world competition???
« Last Edit: April 24, 2023, 09:52:33 AM by Clint Ormosen »
Offline Paul Walker
Re: The B-17
« Reply #3 on: April 23, 2023, 11:05:55 PM »
And, it has been converted to electric. Awaiting ESC's from over the pond. It will have the next generation timer in it  which likely will make it fly better. Hope to fly it this fall.
Offline Paul Walker
Re: The B-17
« Reply #4 on: April 23, 2023, 11:07:57 PM »
The real question will be if my 23 year older body can still handle the line tension.
Re: The B-17
« Reply #5 on: April 23, 2023, 11:11:45 PM »
Thanks ,
good to know its still ' operational ' .
Did the halifix & chickened out at a Profile , got 8 old OS max .15s , but I'll only use Four .  S?P
Its all primed out in silver , fins to fit & landing gear & tanks to do . A STIRLING WING accomanies it here ,
Id thrown out a old battlescarrred Spit. fuse Id meant to keep for MOULDING SHELLS on .The B-17 could be got pretty light , maybe ? . Stressed Skin & Carbon Viel or f' Glass , whatever the Yatesenkos run ?
for cover .
 LL~
Brian Eather uses Estapol 7008 on BARE WOOD , s f a else . Both sides , inside & Out , It'd give enourmose shell strength for V little weight . Maybe spiral bound 1/32 x 1/8 ' formers ' were required . bit like' Al's ' .
Re: The B-17
« Reply #6 on: April 23, 2023, 11:24:32 PM »
The B - 17 fuselage is similarly shaped to a MOSQUITO's , so V Similar ' load bearing characteristics ' . Essentially 3 dimesional curves give enoumous strength per weight . Wood is as strong as steel . Per Weight .
Heres some australians building big control line B - 17 fuselages . Er , Mosquitos . Only about 3/8 thick , in that size .
https://www.peoplesmosquito.org.uk/2015/11/25/the-mosquito-at-75/
Another advantage iof Timber , is it lets the bullets out .  :-\
Re: The B-17
« Reply #7 on: April 24, 2023, 09:02:38 AM »
Oh cool.  I was going to point out that this sort of thing should be easier with electrics -- I guess we can ask you when it flies if that's actually the case.
Offline kevin king
Re: The B-17
« Reply #8 on: April 24, 2023, 09:42:15 AM »
 Ummm. I uuh. I built a Flite Streak one time.
Re: The B-17
« Reply #9 on: April 24, 2023, 09:54:48 AM »
Will the overall weight stay about the same?
Offline Paul Walker
Re: The B-17
« Reply #10 on: April 24, 2023, 10:20:14 AM »
I tested the motors on the first B-17 a few years ago
 Batteries, ESC and timers in each nacelle. Batteries not big enough for full flight. It proved the motors were clearly big enough.
Offline Paul Walker
Re: The B-17
« Reply #11 on: April 24, 2023, 10:21:51 AM »
Surprisingly, it should be close even with the battery installed.
Rick_Huff
Re: The B-17
« Reply #12 on: April 24, 2023, 02:50:59 PM »
Paul,
What ESC's are you going to use?
Rick
Offline Sean McEntee
Re: The B-17
« Reply #13 on: April 24, 2023, 04:35:28 PM »
   I remember seeing it at the '01 Nat's; it was impressive to even a snotty-nosed kid who didn't "get it" yet ;D
   I imagine, if one were to start with a blank sheet of paper, engineer and build one specifically for an electric setup, that there might be at least a bit of weight saved, and therefore not quite as much of a bear to fly?  Not that I would wish such a thing on anyone...
Re: The B-17
« Reply #14 on: April 24, 2023, 05:56:40 PM »
Yeah I remember watching him fly one at the ‘95? (Pasco, WA) NATS. I just don’t know if it’s the same B17.
That’s when I was first getting into stunt and I was in my early 20’s. I didn’t know a damn thing!
Re: The B-17
« Reply #15 on: April 24, 2023, 06:41:52 PM »
One thing one could do for starters is to go smaller.  In '95 using .15's would have been pushing the low-displacement end of the reliability envelope -- today you could use "10-sized" motors or smaller without loss of reliability.
So -- you could start drawing up plans for a 'lectric B36 stunter.
Re: The B-17
« Reply #16 on: April 24, 2023, 07:04:06 PM »
 I was honestly hoping not to hear that, but also figured it would come up. Functionality and ease of operation way up I suppose, but cool factor way down, JMO. Still one of the coolest and most impressive C/L models ever built though.  y1
Offline Paul Walker
Re: The B-17
« Reply #17 on: April 24, 2023, 08:48:35 PM »
Paul,
Rick
Jeti spin 20's
Offline Paul Walker
Re: The B-17
« Reply #18 on: April 24, 2023, 09:00:57 PM »
And that is a good part of the reason it has not  flown since 02
 I wanted to maintain the 4 15's.. As such, either would likely never have flown again.
But the urge to see it/them fly again led to the electric option. The first (used at the 95 Nats) was converted such that nothing was cut or removed so it could fly with slimers in it again. The second has had some critical pieces removed to make room fir one big battery. The wing is still useable either way but I swore I woukd never use that pressure fuel system again.
Tim, I have already designed a 700 in^2 version with 4 smaller electric motors. Expected weight was 65ish ounces. But, I am doing this (using a previous B-17) to see one fly again, and to get it out of my system, so I can concentrate on my next WW2 project. That one is likely a two year build....
« Last Edit: April 24, 2023, 09:43:51 PM by Paul Walker »
Re: The B-17
« Reply #19 on: April 24, 2023, 09:26:01 PM »
 A B-36? It would be easy with electric power.  S?P :##
Offline Paul Walker
Re: The B-17
« Reply #20 on: April 24, 2023, 09:41:55 PM »
I don't want to step on Jim Aron's toes....
Re: The B-17
« Reply #21 on: April 24, 2023, 10:10:24 PM »
 Right, I remember seeing some wing construction photos of that one on his website a long time ago. Never saw a finished product though.
Re: The B-17
« Reply #22 on: April 24, 2023, 10:12:47 PM »
   That was of the first one, intended for 6 061s, he has another one with 6xelectric.
Offline Gary Dowler
Re: The B-17
« Reply #23 on: April 25, 2023, 04:15:15 AM »
Id come help mow your field for the chance to watch!
Offline Uncle Jimby
Re: The B-17
« Reply #24 on: April 25, 2023, 10:36:57 AM »
Here are a few pix.  It currently is forlornly sitting in a corner of the workshop awaiting my attention.  Fuse and tailfeathers in primer ready for final assembly.........someday!
Re: The B-17
« Reply #25 on: April 25, 2023, 12:37:16 PM »
Paul and Jim, I do hope you both get the B-17 and B-36 flying. while the Old DOC cab still read about them. D>K
Offline Matt Colan
Re: The B-17
« Reply #26 on: April 25, 2023, 04:45:30 PM »
Jim, I will only be impressed if you add 4 EDF’s in the engine nacelles…only then will I be impressed
Just kidding! That’s wild stuff! Love it!!
Re: The B-17
« Reply #27 on: April 25, 2023, 07:01:03 PM »
How much does the ENTIRE B - 17 electrickery weigh ?
are you looking at doing a follow up dedicated version ?
thanks .
Offline GallopingGhostler
Re: The B-17
« Reply #28 on: April 25, 2023, 08:16:32 PM »
So true! That was very fine piloting and the aircraft is amazing, with all 4 turning, and scale at that. Inside and outside loops. square loops, inverted, 8's, square 8's, did it all, wow! Also thought it amazing that he had all 4 engines quit the same time. He also hung on to it as though it had normal pull, but it must have had some tug on it.
Thanks for sharing that! Thoroughly enjoyed watching it!  H^^
Re: The B-17
« Reply #29 on: April 25, 2023, 08:31:32 PM »
    Even launching it is a real strain, it pulls hard on the ground, and the span of the stab is so big that you have to sort of stretch out over horizontally to hold it, so it's like holding weights with your arms fully extended. Normally you want to launch any airplane by holding the wing near the fuselage, and that is A LONG WAY from where you have to squat.
Re: The B-17
« Reply #30 on: April 25, 2023, 08:41:39 PM »
 That "someday" is here Jim, that thing is too cool to not get finished.  S?P
 Did the .061 version ever get finished?
Offline Uncle Jimby
Re: The B-17
« Reply #31 on: April 26, 2023, 08:27:26 AM »
No.  I realized that I was going to have to add so much weight to the nose to obtain a viable CG that it just wasn't going to work.  Less of a problem with the electric.
Re: The B-17
« Reply #32 on: April 26, 2023, 08:32:36 AM »
The very first versions that flew didn't have the jet engines.  So there's a true-to-scale dodge for that.
Re: The B-17
« Reply #33 on: April 26, 2023, 09:57:38 AM »
Wont be true-to-scale unless one of the engines catches fire
Re: The B-17
« Reply #34 on: April 26, 2023, 01:00:46 PM »
Which is why you won't see me building a semi-scale stunt Martin 0-2-0 -- making the wings fall off in mid-flight is just too much trouble.
Re: The B-17
« Reply #35 on: April 26, 2023, 06:21:25 PM »
  LL~ LL~ LL~
Re: The B-17
« Reply #36 on: April 26, 2023, 09:08:38 PM »
     "Five turnin' and one burnin!"
    Dad
Re: The B-17
« Reply #37 on: April 26, 2023, 09:54:28 PM »
Speaking of that , the recent hollywood remake of this , theyre more like madona with herepants on fire .
To Quote Miles Trip , Theyed still complain if you pissed on it to put it out . a good Aussie W W I I coloquealism .
A good read. Generally lacking in hysteria. Praise the Lord .
Offline Uncle Jimby
Re: The B-17
« Reply #38 on: April 27, 2023, 08:48:48 AM »
Yep.  And the paint scheme will reflect that model, but I have to say, Matt has got me thinking....always dangerous.
Re: The B-17
« Reply #39 on: April 27, 2023, 02:17:01 PM »
Surely someone makes a smoke generator for electrics.
Re: The B-17
« Reply #40 on: April 27, 2023, 03:35:41 PM »
You can build another one now.  Gotta keep is shape, you know.
You get more points for every plane you build a plane.
Phil Cartier
Offline Pat Johnston
Re: The B-17
« Reply #41 on: April 27, 2023, 04:45:20 PM »
Try this one.  B-17G.  595 squares, 46 ounces, four electric 1/2A motors swinging 6-4 props.  Full pattern capable.  Fun.
Pat Johnston
Idaho Skunk Works
Re: The B-17
« Reply #42 on: April 27, 2023, 07:17:36 PM »
Pat, that is quite a looker, that would be real fun.
Re: The B-17
« Reply #43 on: April 27, 2023, 08:04:36 PM »
Phil Cartier
A FOUR Engined Flite Streak'd gotta be mean .
The little B 17s cool . Dont let someone suck you into haveing a dogfight with them , with it .  >:(
Re: The B-17
« Reply #44 on: April 27, 2023, 08:42:35 PM »
 Ok, when do we get to see the finished electric version?
Offline Norm Faith Jr.
Re: The B-17
« Reply #45 on: April 27, 2023, 09:26:39 PM »
Paul, are you going to use one "large" battery for all four motors? Would that be possible?
Norm
Circlepilot   AMA9376
Re: The B-17
« Reply #46 on: April 27, 2023, 09:48:00 PM »
I had the honor to lead an active duty, Air Force crew out of Eaker AF Base, that assisted in the first restoration of the Memphis Belle, that we moved to Mud Island, Memphis TN. 1987. Got to spend time with the original crew and Marget Polk, the "Memphis Belle" herself. These are the waist gunners Winchell and Nastal and myself.
Norm
Circlepilot   AMA9376
Re: The B-17
« Reply #47 on: April 27, 2023, 09:58:13 PM »
Norm
I'm the "short dude with the shoulder boards.  ;D
Circlepilot   AMA9376
Re: The B-17
« Reply #48 on: April 27, 2023, 10:01:35 PM »
The Belle's crew.
Circlepilot   AMA9376
Offline Paul Walker
Re: The B-17
« Reply #49 on: April 27, 2023, 10:15:48 PM »
Norm
Yes, one single battery. Only question is the capacity. Made extra room fir a longer battery.
