The days gone have shown that back then they used 45 degree deflections. Today it is more like 15 degrees. So how did this evolution take place. I hope to see a lot of discussion on this from higher skill fliers on this subject.
Thanks Chuck
What they said was going on, and what actually happens is two different things. They didn't use 45 degree deflections in the good old days either. There wasn't anything like the necessary line tension to deflect the controls that far in flight. You could get them to move that far on the ground, but you can do that today, too. In-flight pictures of classic planes flown today show tiny deflections even when flown hard. As with most technical questions, Bill Netzeband knew all about this back in the 50s when it was going on, and it's called the "Netzeband wall" - the line tension and mechanical advantage of the control system was inadequate to deflect the surfaces into the airstream very far.
If you tried to overcome this with engines and engine setup of the day by altering the control system, it didn't work anyway. If you manage 30 degrees of flap and elevator on a Fox 35/Nobler you are going to damn near stop dead in the air due to the huge drag and feeble power and speed stability. So even if you could have done it, you wouldn't want to, because you might get one great corner but the rest of the maneuver suffers or can't be completed. Do that at the first corner of the hourglass, and you aren't making it to the top.
Current airplanes need less deflection for the same sort of corner because the CG is generally much further aft, made possible by much larger tail volume. They area also capable of much more in-flight deflection if needed, because the mechanical advantage of larger bellcranks and generally more solid line tension - and generally smaller control surfaces. At this point you have to limit the tightness of the corners for reasons other than the Netzeband wall, mostly, you still have to control the exit angles. Still, at the highest levels of competition, we are still cranking the corners about as hard as we think we can reliably do. Steve Fitton has posted a picture of me at the 2011 NATS with a handle angle corresponding to maybe 35-40 degrees of control deflection.
An interesting effect of the Netzeband wall is how the airplanes responds through a corner. Old airplanes take a long time to start the corner, due to the low angular acceleration. While it's cranking up the corner, it's also slowing dramatically - which reduces the control loads and for given control pressure, allows the controls to deflect more. Which makes it accelerate in rotation even faster. So when flying them, the effect is that the entry is very "swoopy" and then it tends to "wrap up" into an ever-tighter corner. Then you have to stop it, and the reverse tends to happen - although not as dramatically since you are already slow and the engine (if set per standard 4-2 break practice and working perfectly) is starting to crank up. So the shape of the corner is nothing like a constant radius curve, it's sort of a lopsided hyperbola. You can see this even in the old pictures where they put flashlights on the wingtip, or use movie frame stills.
More modern airplane, say, the prototypical top gun airplane, the Impact/40VF, as trimmed and flown by Paul Walker, has close to none of this. You can achieve the desired radius almost immediately, hold a constant tight radius , the kill the rate almost immediately. There's not a lot of drag, there's excellent speed stability and you have enough control margin to get whatever deflection you need and hold it. Paul is an absolute master at taking advantage of this which is why he was completely untouchable in the early 90's and still one of the the guys to beat today - after some of us caught on to the trick to one degree or another, and managed to use it to varying degrees of effectiveness.
This type of performance has a lot of implications that you wouldn't necessarily expect. The engine performance and response in a corner is *absolutely critical* to the turn performance. That's why you see such endless talk about engine setup on TP engines - it's not because they are fussy or unreliable, it's because we are trying to get the engine to respond just right to make it as easy as possible to do the corners. Because if you get it wrong, and someone else gets it right, you lose. The other effect is that it puts *extreme* stress on the airplane, particularly the wing. We have had more wing failures since 1990 than I saw or heard of in the preceding 40-50 years. We keep building them stronger and stronger and they last a lot longer now than they did with old-style construction and the "lighter is better" theory, but there are still problems sometimes. Ever piped airplane I ever built was stronger than the last, but they have all ended up needing some sort of repair due to flight stresses.
