  • July 03, 2025, 06:22:09 PM
Author Topic: TF TUTOR  (Read 1173 times)
Offline Guy B Jr
TF TUTOR
« on: October 22, 2020, 11:08:53 PM »
Anyone have any experience with the Top Flite Tutor set up for an OS FP .20 running a la Brett Buck. This 45" w/s kit looks as if it fits the bill.
Guy Blankinship
Re: TF TUTOR
« Reply #1 on: October 22, 2020, 11:25:52 PM »
   I have used both the airplane and the engine, but not at the same place at the same time. However, you are absolutely correct, it should be a nearly perfect combination. You might want to shorten the nose an inch or so.
Offline Phil Spillman
Re: TF TUTOR
« Reply #2 on: October 23, 2020, 07:33:40 PM »
My old and over used original Tutor flew great with a Brodak .40 on muffler pressure and swinging an 11 X 5 prop and sometimes an 11 X 4 narrow blade prop. I put on over 375 flights before it met its end! A real fun flyer and from time to time competitive. Add wing tips and try to keep it light. I have my doubts about the FP .20 but I could be corrected / persuaded to relent I have used this engine on many Ringmasters and Mustangs as in Sterling kits! The Brodak versions fly better because they are lighter!
Phil Spillman
Phil Spillman
Offline Kreth
Re: TF TUTOR
« Reply #3 on: October 27, 2020, 06:03:51 PM »
Hi Guy,  Long time since contact.  Arlan my son and I have been flying one for years with a Fox 35.  Should fly just as well with a .20 FP.
Kreth McKee AMA 22004
