  • June 24, 2025, 08:25:20 AM
Author Topic: Anybody used Eze Dope?  (Read 3275 times)
Offline pipemakermike
« on: December 17, 2013, 06:30:15 AM »
I have just heard about this product and wondered if there was any experience with it on the forum.
Mike Nelson
Offline Mike Lauerman
Re: Anybody used Eze Dope?
« Reply #1 on: December 17, 2013, 10:08:44 AM »
Haven't seen it yet, Mike. Is it available in the U.K. exclusively, or has it reached the colonies???
« Reply #2 on: December 17, 2013, 10:16:51 AM »
well, it has made it to Australia So it has reached at least one colony<G>
http://www.christiantraders.com.au/contents/en-us/d55_Eze-Dope.html
A bit of a search shown that it is available in the US:-
http://www.horizonhobby.com/webapp/wcs/stores/servlet/SearchCmd?searchKeyword=eze+dope&searchType=productgrid
Mike Nelson
Offline Kozmo77
« Reply #3 on: December 17, 2013, 11:49:07 AM »
water clean up? what's with that? %^@
« Reply #4 on: December 18, 2013, 01:53:14 AM »
The solvent is water and it claims to have no smell. I have just bought a bottle and will report.
Claims are that it will shrink tissue like conventional dope, has no smell and is hot fuel proof
Sound too good to be true but time will tell
One thing I haven't seen is if it is usable on sheet areas.
Mike Nelson
« Reply #5 on: December 18, 2013, 01:59:15 AM »
  Try searching EZ-Kote. It's been discussed here or on Stuka before, and I was able to have the hobby shop order it for me from either Great Planes or Horizon Hobbies. A little different name, but label art and contents look similar. I wanted to try it as a base for a rattle can finish on a small model. Hope to get around to it this winter.
« Reply #6 on: December 18, 2013, 02:04:25 AM »
Mike Nelson
Offline John Craig
« Reply #7 on: December 18, 2013, 06:44:38 AM »
SWAG:
I will put my money on poly-acrylic = water based poly-urethane. Same as the water based varnishes found at the big box stores.
« Reply #8 on: December 18, 2013, 09:29:15 AM »
Didn't the Barton site have quite a bit about this stuff just a few years ago?
« Reply #9 on: December 21, 2013, 08:41:14 PM »
I've used polycrylic on paper, thinned about 50% as mentioned on rcuniv.  Initially it worked well.  But after a short time the covering got extremely hard and brittle.  The slightest bump would poke a hole.
I believe that is because all the stuff available as paints are formulated mainly as floor finishes.  In fact, the most fuel proof one, Varathane, is labelled "diamond hard"  which should be a clue.
Offline Jim Thomerson
« Reply #10 on: December 22, 2013, 10:06:28 AM »
There is an extensive review in Aeromodeller, Jan-Feb 2014.  Sounds very interesting.  Reviewer covered a small stick and tissue rubber model using it and did bang up job. Said to be fuel proof.
