  • July 14, 2025, 08:33:37 PM
Author Topic: Tanks  (Read 1790 times)
Offline kevin king
Tanks
« on: January 26, 2022, 09:46:51 AM »
Where are all the tanks? These are the only ones ive used on full fuselages, i checked Brodak and didnt see any. Its for a Vector 40 with Os La 46, and seems the largest tank that i can fit is 5oz. I want the same set up as the ones in the photo. Two pipes in the front, uniflow and fuel feed to engine, and one overflow on the top.
Offline Al Ferraro
Re: Tanks
« Reply #1 on: January 26, 2022, 09:59:02 AM »
 The tank BH532, 4-1/2 oz is what I use in my Vector with a LA 46. The 5oz is a BH533
Al
https://brodak.com/wide-wedge-magnum-uniflow-fuel-tank-4.html
Offline Carl Cisneros
Re: Tanks
« Reply #2 on: January 26, 2022, 10:29:43 AM »
might want to check this one out as well.
bout the closest one to the one you have in your picture.
it is a 5 oz. tank from Brodaks.
Carl
https://brodak.com/fuel/fuel-tank/a-t-f-wide-wedge-uniflow-fuel-tank-5-oz.html
p.s. also check out the ones at RSM      https://rsmdistribution.com/index.php
Carl R Cisneros, Dist IV
Control Line RB
Offline Mike Griffin
Re: Tanks
« Reply #3 on: January 26, 2022, 10:44:57 AM »
You might check with RSM Distribution.
Offline Dwayne Donnelly
Re: Tanks
« Reply #4 on: January 26, 2022, 11:04:23 AM »
Offline big ron
Re: Tanks
« Reply #5 on: January 26, 2022, 11:28:55 AM »
RSM GRW500WU
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline dale gleason
Re: Tanks
« Reply #6 on: January 26, 2022, 11:37:28 AM »
I like the RSM tank kit, comprised of copper tubing, tank ends, and a long tank body. Cut the body to the desired length, solder one end cap on, punch holes for the copper tubing, solder in place, then solder the last end cap. Test for leaks, done.
This tank is ez to build and works very well.
dg
Offline Dave Harmon
Re: Tanks
« Reply #7 on: January 26, 2022, 03:50:12 PM »
For some time I have been building my own tanks from the Brodak kit.
This is a 4oz I made for the Vector.
Really easy to do, the parts fit and you can make the uniflow exit where ever you want.
On my first Vector tank I had the exit for the uniflow like yours but it interfered with the manifold on the side of the fuse so the next time I made a tank I moved the uniflow exit next to the feed line.
Of course both tanks had copper tubing and the uniflow line was soldered to the feed line at the rear of the tank in the usual manner.
Both tanks work perfect for a nice 4-2-4 engine run.
I got into building my own tanks because I was having a lot of engine run problems with the awful workmanship of the store bought tanks internal plumbing.
To fix it I was having to open the back of the tank anyway so I just started using the kits.
Whoever is assembling those tanks just does not have the slightest clue how to solder....they might as well have used Comet glue, Sigment or Ambroid....if they could find any....to build those crummy tanks....snarl... ~^
Offline Paul Van Dort
Re: Tanks
« Reply #8 on: January 27, 2022, 04:25:48 AM »
Many of us use RC style tanks with 1 clunk for feeding and a fixed uniflow tube. The heigth of the uniflow outlet in the tank is your relative tank heigth. Works perfectly.
Offline kevin king
Re: Tanks
« Reply #9 on: January 27, 2022, 08:39:35 AM »
Tanks everyone!⭐⭐⭐⭐⭐
