  • July 28, 2025, 03:29:57 AM
Author Topic: tank stock  (Read 1562 times)
Offline Bootlegger
tank stock
« on: February 03, 2009, 09:45:34 AM »
 I am looking for some .008 tin stock to build tanks with. Where can I get some? The size sheets that I need will be about 6" wide in a roll .  Suggestions ??? #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: tank stock
« Reply #1 on: February 03, 2009, 10:02:43 AM »
http://www.mcmaster.com/#brass-shims/=fyhwq
I use brass myself.  I E-ordered some .010" and .007" on Monday morning and had it by Tuesday afternoon.   If you dig through their online catalog, you might find some steel or tin or tinplate, otherwise, brass makes a fine tank.
Offline Bill Gruby
Re: tank stock
« Reply #2 on: February 03, 2009, 10:06:30 AM »
 Ace Hardware orders mine from K&S. It's 6 X 12 X .008. I have it within 48 hours.
  "Billy G"  #^
Bill Gruby
AMA 94433
MECA 5393-10
Re: tank stock
« Reply #3 on: February 03, 2009, 11:42:34 AM »
Any good Mill Supply should have what you need...I use brass myself; 6" wide roll x 3' long has made around ten tanks so far...just finished one for my new airplane....I hate leadless acid core...that stuff is a nightmare on a cold iron! ;D
Offline Bootlegger
Re: tank stock
« Reply #4 on: February 03, 2009, 01:44:52 PM »
Thanks guy's, I knew that ya'll would come thru.... ~>
Gil Causey
AMA# 6964
Offline Phil Coopy
Re: tank stock
« Reply #5 on: February 04, 2009, 08:37:06 PM »
try Googleing  McMaster-Carr   they have everything you could use in hardware and raw materials.
Phil
Re: tank stock
« Reply #6 on: February 04, 2009, 10:26:46 PM »
Brass will develop leaks.  I just made a nice little tank out of the bottom of a Danish cookie tin.
  • Gravitywell
Re: tank stock
« Reply #7 on: February 05, 2009, 01:02:53 AM »
I make all my tanks from paint thinner tins I get from my local autobody repair place.  I ask them to save them for me in a supplied garbage bag.  One bag full generally costs me a dozen home made cookies! LL~  The tin is very nice to work with. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: tank stock
« Reply #8 on: February 05, 2009, 08:02:56 AM »
Speaking of tins...I have made several tanks from those big peach cans....none have rusted nor have any leaks. Having said that, only one of my brass tanks has developed a leak, and that happened in a crash! H^^
