I'll post these pics of my tank setup.
Just did some static tests to compare to flying. Seems my static run time is almost double flight time at similar throttle settings. This surprises me.
Tank capacity is 7oz. The only full tank flight to date lasted about 7 minutes , static run today was 12:26 with the same 11/7 TopFlight prop. Avg rpm at 3/4 throttle (where it flies best) was 9000-9200, max rpm was 10100. (10/20 fuel, 50/50 syn/ castor). Switching to a master airscrew 11/4 nylon prop brought run time to 10:30, and max rpm to 13,500.
This is before adding end cap on the tank. Shown sitting on the outboard side of the tank. Note uniflow vent terminating near fuel pickup line.
Basic installation of engine and tank.
Completed tank. Outboard side atvtop
So the basic question is, why is there such a difference in flight time vs static run time? True to uniflow use the overflow vent is capped on every flight so I can't have a fuel siphoning issue due to the airstream, I don't think.
No changes were made to needle valve setting.
