  • June 17, 2025, 05:33:59 AM
Author Topic: tank painting...........................................  (Read 1891 times)
Offline larry jaconetta
« on: June 26, 2006, 10:55:48 AM »
 i've painted a lot of things in this mans hobby, but i never had the oportunity to paint a metal fuel tank until now.
i've always had tanks inside--outside--brass--plastic, but now I want to paint it to match the plane. I have to use the same color dope on the tank! My question is, what type of prep do i do, to get the surface to accept dope, and not come off after 10 or 20 flights?
                                                     keep sanding
                                                              larry J
Online RC Storick
Re: tank painting...........................................
« Reply #1 on: June 26, 2006, 11:06:50 AM »
I would use some kind of self etching primer (automotive type) then  paint with the dope and top coat with automotive two part urethane.
« Reply #2 on: June 26, 2006, 08:37:33 PM »
Just a thought, but can a tank be anodized??  That would be cool <=
If it's an aluminum alloy.  y1  n~
Bill <><
« Reply #3 on: June 26, 2006, 08:39:47 PM »
Hi Larry,
I painted a coule tanks for use on profiles.  I used an automotive primer, dope and urethane auto clear over the top, like Sparky said.
Everything is fine so far!  (and one has had quite a bit of use.  y1  %^
Bill <><
Offline Greg Hart
« Reply #4 on: June 30, 2006, 12:20:32 PM »
If its a metal tank just roughn it with sand paper and start painting light coats of paint, then finish with a couple heavier coats, then clear. I used Brodak and have had not chip problems, photo has my Cardianl with a painted tank
BUY A UKEY AND LEARN
