  • June 16, 2025, 11:46:51 AM
Author Topic: Tank height for upright Fox  (Read 3371 times)
Offline John LeBlanc
« on: March 07, 2006, 08:11:01 PM »
After sitting for a several years, the bislob box finally came out of the closet, and parts are going together fast.
Question: How high should the centerline of the tank be to get the old Fox 35 (mounted upright) to run evenly on inside and outside turns? I'd prefer to use a normal metal CL tank, unless someone can tell me a good reason why I should go to an R/C clunk tank on this design.
Also, I've had problems years ago with fuel foaming due to vibration. Anything I can do to prevent this?
Re: Tank height for upright Fox
« Reply #1 on: March 07, 2006, 08:25:04 PM »
On the BiSlob, just run a standard vented tank... if your engine is on the bearers, let the tank sit on the bearers also and it should be fine.  This is all assuming a standard CL type tank.
Alan Hahn
« Reply #2 on: March 07, 2006, 08:34:59 PM »
On a Bi-Slob, you are running very rich, so the rpm's probably will be too low to hit a resonance in the fuse. However, just in case you do, a few drops of original Armourall vinyl  cleaner to a gallon of fuel will go a long way to stopping the foaming.
Offline frank carlisle
« Reply #3 on: March 08, 2006, 02:58:01 AM »
brodak sells a tank for the bi-slob, the part number should be on the box. i looked it up in the current brodak catalog. the part # is:BH598...4 oz. profile tank-$10.00.
Frank Carlisle
