  • June 17, 2025, 03:48:03 PM
Author Topic: Need a canopy  (Read 1479 times)
Offline Vincent Corwell
Need a canopy
« on: September 12, 2007, 12:57:57 PM »
Hi all
Anybody know where I can get a canopy
for Kim Webbys CAP 21, ( New Zealand )
this was a Flying Models plan
thanks friends
Vincent
Offline Rudy Taube
  • Ret Flyboy
Re: Need a canopy
« Reply #1 on: September 12, 2007, 02:31:58 PM »
Hi Vincent,
This may be as close as you can get. It is for a .40 size CAP 21. The dimensions are given so you can check your plans before you order. You may find it easier to make a small adjustment to the plane so that it fits an available canopy?
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ941&P=7
What issue of Flying Models had this CL Cap 21? TIA :-)
Rudy
AMA 1667
Re: Need a canopy
« Reply #2 on: September 12, 2007, 02:39:39 PM »
thanks Rudy
I have the plan, lost the mag, 1960's I think
most of the RC canopies are too wide,
designed to house 3 servos across
so circa 5 - 6" wide , the CL plan
shows 3 1/4" at the canopy front
Found the date of plan/article  January 1997 !!
Appreciate your reply
Happy landings
Vincent
« Last Edit: September 12, 2007, 03:07:26 PM by Vincent Corwell »
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Need a canopy
« Reply #3 on: September 12, 2007, 03:03:13 PM »
Wonder if Tower is selling the canopy for the Score yet.. Bet it would be just about perfect.
Offline ash
Re: Need a canopy
« Reply #4 on: September 12, 2007, 08:29:52 PM »
Kim made his canopy himself. The model was built in about the early '90s for a WC he went to, so chances are slim that he still has the plug although it is possible since he does hoard stuff like that!
I hear that the original has recently met its demise in practice for the next WC. Its a CAP20, by the way. Slightly different to the CAP21.
Re: Need a canopy
« Reply #5 on: September 13, 2007, 11:24:18 AM »
Thanks Adrian
that is a typo I have the plan, read CAP 20
but write CAP 21....must be old age
Vincent
