  • July 14, 2025, 08:42:23 PM
Author Topic: FYI for Gilbert .11 fans  (Read 870 times)
Offline Terry Caron
« on: October 24, 2016, 11:50:36 AM »
In case you ever need to know.
I got a wild hair yesterday to put mine on the bench again just for funzies.
Fiddlin' around and I lost the copper head gasket - long story short, the Grass Gremlins apparently ate it.
The gaskets seem to be impossible to find online so I dressed the head's mating surface on fine sandpaper and it seems to seal and run fine - 14.7 K/6.5x5.5 MA/15% nitro.
Runs with other prop sizes show it to be, as is often stated, in the same power class as most .09s of it's day.
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline James Holford
Re:
« Reply #1 on: October 24, 2016, 12:11:04 PM »
I have one brand new never run.....i wonder if it would be a good runned for a Jr. Lightening Streak :p
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Terry Caron
Re: FYI for Gilbert .11 fans
« Reply #2 on: October 24, 2016, 12:25:25 PM »
I haven't had mine in the air, John, so no report from the trenches. MOF, I don't recall a report from anyone who has.
Wanna be the first?  ;D
I suspect it would fly a JLS, but others have suggested something in the 180-200 sq. in. range might be a better candidate.
As a further note, I ran it with an 8x4 MA with 2 different heads (see combustion chamber pic below).
The shallower head seemed to run ~200 rpm faster than the deep head, 10.2K v 10K. YRpmMV.
A forum search for Gilbert .11 should return several threads about 'em.
« Last Edit: October 24, 2016, 12:44:19 PM by Terry Caron »
AMA 249824
NRA Life Member
Offline Herman Green
« Reply #3 on: October 24, 2016, 01:19:53 PM »
I think I have four new .11's and four new .07's that I've never run.  Maybe I'll get them out and play with them a bit.  I have some of the headers for the .11's but I don't think I do for the .07's.
Herman
Herman Green - 164164
Offline Terry Caron
« Reply #4 on: October 24, 2016, 01:50:35 PM »
You'll find them, Herman, easy starting (in either direction!), friendly engines.
FWIW, I'll repeat here that the .11s were designed by Bob Holland (of Hornet fame) and built by Hy Johnson's Dynamic Models for Gilbert, who later took over manufacture of both sizes (.07 built by Gilbert only). They were in production for only 3-4 years IIRC.
Though glow heads from the Fox Rocket .09, Fox .10 and Hustler .10 will fit the Gilbert .11, Fox had no significant involvement in the Gilberts, despite the external resemblance of his .09.
« Last Edit: October 24, 2016, 03:13:09 PM by Terry Caron »
AMA 249824
NRA Life Member
