On the other hand, if you build your stabalizer strong enough to repeatedly abuse in such a way, your plane is probably tailheavy. I would suggest an anchor eye about midway between the flap TE and stab LE, then clip a cable or nylon cord onto that when you need to use a stooge. If you're using a trike LG, you might want to move the attachment farther forward, perhaps near the flap hingeline. I'll let Tim run the numbers and finger (sic) it out for me.
Steve, I politely disagree. I really don't think restraining a model by the leading edge of the stabilizer, puts as much abuse or stress on the tail as restraining by a tail wheel wire, whether it be 1/16 or 3/32 in diameter. The stress is spread out by a much larger area in the stab / fuselage joint than it is with a wire and it's attachment.
My stabs are built up with a molded leading edge with ribs and full sheeting. All material is 1/16 balsa including the rear spar. Small balsa plugs are inserted where the hinges are located. It is essentially a small torque box, very light and stiff. No other reinforcement is used.
After several hundred launches, using a leading edge type stooge, I have seen no signs of damage, to the leading edges of the stab or in the fillet area. My stooge is padded where it contacts the model. Also, I generally need to add tail weight to my models.
When you think about it, how much abuse does a tail get when it is held by a person when launched? Seems about the same amount as a leading edge stooge and no one questions it.
Not trying to pick a fight, just trying to explain my reasoning.
Safe and happy launching;
Larry
