  • July 01, 2025, 04:22:45 PM
Author Topic: Tail booms on a Voodoo  (Read 1716 times)
Offline Mike Griffin
« on: April 11, 2018, 07:42:20 AM »
I have a Voodoo kit that came with two sets of plywood tail booms.  One set is longer than the other.  What does the longer set of booms offer in how the plane will fly as opposed to using the shorter original set?  For example, by using the longer set will the model corner better?
Thank you
Re: Tail booms on a Voodoo
« Reply #1 on: April 11, 2018, 09:28:32 AM »
The extended booms on the VooDoo, Sneeker and a few other older designs were a later upgrade to keep the airplanes more competitive with heavier BB engines against more modern designs.  Turning radius is/was almost everything in combat.  The extended tails gave the stabilator more leverage. Later designs usually had more wing area, better airfoils and longer booms.
« Reply #2 on: April 11, 2018, 11:41:57 AM »
Hi Mike,
Hey if you're just looking for some fun with a Voodoo a FP or LA 25 with the short booms with the engine on pressure and a .325 venturi, flies about 80 mph.  With a Fox 36X and the long booms they will fly about 115...
Fun either way but I suspect you will have more fun with the former setup!  LL~ LL~ LL~
Offline kenneth cook
« Reply #3 on: April 11, 2018, 11:58:09 AM »
               Mike, may I suggest that you don't follow the building instructions for attaching the elevator to the booms. The  L shaped pins they recommend are notorious for failing. Your much better off using a continuous piece of music wire with epoxy and glassing over it in the center to retain it. It also aligns it better in the event one side is slightly off. I used two triangles of 1/64" ply slightly extended over the leading edge of the stab to create a channel which I was able to get decent glue area.
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: April 11, 2018, 12:00:43 PM »
All good info here. If you ain't got an engine, let me know. We'll get you all fixed up.
« Reply #5 on: April 11, 2018, 12:53:13 PM »
Thanks everybody for the great input.  In all my years of flying model airplanes, I have never built or flown a combat type model.  Dont know why, I just never did for some reason so this is new ground to an old dude like me.   Just want to have some fun and see what I can do with it.  Dane I think I am OK on engines but will let you know If I cannot find anything in my stash that will work.
« Reply #6 on: April 11, 2018, 12:55:22 PM »
Hi Mike,
Randy at my age and with my bad back I would probably get sick, throw up and fall down.  LOL.....  We have a guy in our club who flies pulse jets at 150 mph and I get dizzy just watching him.   Guess I am getting old.
Offline Gordon Van Tighem
« Reply #7 on: April 11, 2018, 02:14:50 PM »
Lazy eights, make them big.
Cure for combat speed dizziness.
G
Gord VT
MAAC 3738L, Life Member
AMA C3738L
Offline Chad Hill
« Reply #8 on: April 11, 2018, 02:21:24 PM »
Back in the '70s, when using a heavier ST G21 35 on a VooDoo, it was common to add booms that were long enough to extend the stab 6" from the wing TE to the stab LE. Many guys used Nemesis stabs.
« Last Edit: April 11, 2018, 02:38:49 PM by Chad Hill »
« Reply #9 on: April 11, 2018, 06:17:40 PM »
That's what I did.
Offline Dan Berry
« Reply #10 on: April 12, 2018, 08:58:01 AM »
That's what I did.
Oh, very nicely done!!!!
Offline Chad Hill
« Reply #11 on: April 12, 2018, 02:05:43 PM »
That's what I did.
Gosh, Howard, I didn't realize that you, too, put Nemesis stabs on VooDoos!!   LL~
P.S.-Thanks for that NIB G21 crank you sent me a dozen or so years ago. I put it to good use-
Offline Terrence Durrill
« Reply #12 on: April 12, 2018, 03:37:34 PM »
That's what I did.
[/quote
                                         And how did that work out Howard ? ......   D>K        H^^       LL~
Offline Andre Ming
« Reply #13 on: April 12, 2018, 05:12:19 PM »
LOL!!
That was excellent, Howard.
