  • July 14, 2025, 10:21:37 AM
Author Topic: T-6 update 30 Nov  (Read 1754 times)
Offline Sean McEntee
T-6 update 30 Nov
« on: November 30, 2014, 10:23:11 PM »
Got farther then I planned this weekend.
Was surprised how rigid the fuselage builds up to. Very stiff even without the side sheeting. Added 2 degrees incidence in the stab.  Got the stab started as well. Full speed ahead!
Offline Shawn Lenci
Re: T-6 update 30 Nov
« Reply #1 on: November 30, 2014, 10:33:52 PM »
Sean,
That looks very nice! :)  Do you have any photos of the fuse before the sheeting was added?  I like to see the construction underneath the sheeting.  Is that T-6 one of Don Hutchinson's designs?  If so do his plans show the built up profile fuse construction?
Looking good!
Shawn
AMA 97686
« Reply #2 on: November 30, 2014, 11:04:06 PM »
Hey Shawn,
     Yes this is Dons design, and it does show the built up structure, 1/4x1/2 frame and 1/8x1/2 bracing. The nose is solid 1/2" sheet
Offline Tom Niebuhr
« Reply #3 on: December 01, 2014, 04:54:52 AM »
Sean,
Looks great. Keep up the good work. It is great talking to you too.
AMA 7544
Online Joe Gilbert
« Reply #4 on: December 01, 2014, 06:28:17 AM »
Sean, looking good , when you get it done ,you will be the scourge of the profile circles!
Joe Gilbert
« Reply #5 on: December 01, 2014, 06:33:56 AM »
Yar...  LL~
Online Crist Rigotti
« Reply #6 on: December 01, 2014, 07:13:44 AM »
2 degrees of incidence on the stab?  That seems like a lot!
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: December 01, 2014, 07:58:28 AM »
Can't remember off the top what Joe Gilbert ended up with but am thinking it was around 2 deg. Pretty sure he posted it in one the threads where his T-6 was mentioned but not sure which one. When Don built that T-6 he made the stab incidence adjustable. Whatever it is, it must work. Joe has had what a 3 or 4 year run with that T-6 without being beat in Expert Profile flying it all over the country. I like to think (because I'm biased) the Saito 40 on the nose has something to do with it but in reality it's just a good airplane with good power in good hands.
« Reply #8 on: December 01, 2014, 09:31:36 AM »
Yeah 2 degrees is what Joe ended up at. As for the motor, you are correct. I'm going with a ST 51 for the same reasons: power and more power!  It also eliminates the need to add the 4oz of nose weight per the plans
Christ with the wing so far below the thrust line it helps cornering allot
« Reply #9 on: December 02, 2014, 12:11:43 PM »
I would be a little worried about going up 2 degrees on the stab. I have seen photos of Joe and the elevators show some "up" in level flight. Also, the Dauntless is 0-0 and flies just fine.
« Reply #10 on: December 02, 2014, 09:14:10 PM »
I rigged the controls up on mine and got everything level and it looks the same as Joes.  The elevator is parallel to the centerline.  I think it just looks like a big deal because the stab is so long. Not trying to reinvent your wheel  H^^ just trying to recreate Joes setup
