General control line discussion => Open Forum => Topic started by: RC Storick on September 25, 2007, 06:41:38 PM
Doug showed what he was doing no I will show you what I have been up to. I only got 1 pic before batteries died. Almost ready to join the wing to fuse.
61 inch W.S. 10.25 nose and 18.25 tail. Geo wing.
(http://stunthanger.com/smf/index.php?action=dlattach;topic=6763.0;attach=19377;image)
Looks cool Bob except for the RUDDER! LL~ Just kiddin!!! Looks like another killer in the works. Keep us posted, OK?
park....
Is that a sheeted geo wing? Or a foamy?
If a sheeted geo, why instead of silkspan?
It looks cool!
It is a test airplane so its a foam wing. The difference in weight is only 1 ounce. The flaps are foam sheeted and should make up the difference. I wanted to build the first one rugged for grass flying in the start of the next season. The next one I build will be built up.
Robert,
I remember when you talked about building this model. Is this a kit bashed plane from one of Randy's kits or did you design this one yourself using an SV wing. I cant remember.
I very curious as to how it will compare to your T-Bolts. Keep us updated with some more photos as you have time.
Robert,
SV stands for the wing plotting system. It is not a copy of anything however it uses some numbers that are close to Randy's designs. It is a Geo-bolt airfoil swept back tips like the SV-22. It will look like a RS design but it is my own. Hope it works..
