  • July 08, 2025, 01:54:59 AM
Author Topic: Survey regarding potential new kit  (Read 3138 times)
Offline eric rule
« on: March 23, 2016, 09:54:05 AM »
A couple of years ago RSM Distribution brought out our version of the Tutor profile. The response to this model was quite good and we expanded it to include a Take Apart version. Ever since the introduction of the Tutor we have been receiving inquiries from people asking if we could also offer the Tutor Two.
The Tutor Two was a version of the original Tutor scaled up 20%. This made the wing span increase from the original 45" to 55". It was also only offered as an ARF for R/C.
If RSM Distribution was to offer our version of the Tutor Two it would be 100% laser cut using contest balsa. We would also deliver the kit so that it could be built for either glow or electric power.
What I am inquiring is what interest, if any, is there in the Tutor Two?
Offline ray copeland
Re: Survey regarding potential new kit
« Reply #1 on: March 23, 2016, 10:00:24 AM »
Interested!!
Offline BYU
« Reply #2 on: March 23, 2016, 10:12:47 AM »
Interested! put me down for 1
Online Steve Helmick
« Reply #3 on: March 23, 2016, 12:41:19 PM »
Raise the wing in the fuselage about 5/8" to fix the vertical CG problem the ARF had!  y1 Steve
Offline Steven Kientz
« Reply #4 on: March 23, 2016, 02:38:44 PM »
I'd like one, can you  ballpark a price?
Steve Kientz
AMA 855912
Offline Allan Perret
  • Proverbs
« Reply #5 on: March 23, 2016, 02:51:43 PM »
What's the wing area ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Mike Griffin
« Reply #6 on: March 23, 2016, 03:57:10 PM »
Here you go ALLAN
* Wingspan: 54 in (1370mm) * Wing Area: 594 sq in (38.3dm2) * Weight:
3-4 lb (1360-1810g) * Wing Loading: 12.6 oz/sq ft (38g/dm2) *
Requires: .40-.51 cu in (6.5-8.5cc) C/L engine, line, control handle,
connectors, prop, fuel
« Reply #7 on: March 23, 2016, 04:06:07 PM »
I built several of Eric's original Tutor kits, one for myself and some for others.  It was easy to build and the quality was impeccable. I also had two of the Tutor ll (2) ARFs when they were available from Top Flight and they flew beautifully with a ST .51.
I will certainly take a kit if you decide to produce it.  I will use the Back Tiger electric power system with it as I think this plane would fly great as an electric.
Offline mike londke
« Reply #8 on: March 23, 2016, 05:56:29 PM »
Laser cut Tutor II? You bet. I would take one.
Offline Walter Hicks
« Reply #9 on: March 23, 2016, 10:21:10 PM »
YES one just went for $217 on eBay very good flying plane
Offline 11290
« Reply #10 on: March 24, 2016, 07:50:37 AM »
Couldn't find the "non" take-apart Tutor on the RSM site.  Can anyone provide a link to that page?
Evansville, IN & Orlando, FL
  • Proverbs
« Reply #11 on: March 24, 2016, 12:26:51 PM »
Here you go ALLAN
Is this the same size a the TopFlite ARF Tutor II  ?     If so I would be interested in a kit..
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Dan Labine
« Reply #12 on: March 24, 2016, 12:36:17 PM »
I'm interested!!
Dan
MAAC 14300
« Reply #13 on: March 24, 2016, 01:14:42 PM »
ALLAN I took that off of a website that was detailing the Tutor ll ARF so. Am assuming those are the correct numbers but maybe Eric can confirm it.
Offline Dalton Hammett
« Reply #14 on: March 24, 2016, 06:18:02 PM »
I have a Tutor II ARF and it is a very good flyer with an ST .51.   I likely fly it more than any other plane on the wall.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline Steve Thornton
« Reply #15 on: March 24, 2016, 07:41:49 PM »
Sign me up Eric!
Steve Thornton
"Most of us won't make it out of this world alive."
Steve Thornton
Offline scott v.
« Reply #16 on: March 25, 2016, 04:33:51 PM »
Yes !
Scott V.
Offline eric rule
« Reply #17 on: March 27, 2016, 08:06:39 PM »
There seems to be sufficient interest so I will go ahead with the project.
To date I have the new drawing about 80% completed. As soon as that is complete I will put together the laser cut files and start to run the kits. As is the standard lately the new Tutor Two can be powered by either glow or electric with both mounting systems included in the kit. Just choose the one you wish and you are good to go. Wing construction will be my "MIT Wing" design so it will be easy to construct with leading and trailing edges slotted and notched to accept the ribs in perfect alignment. Laminated fuselage for stiffness to eliminate twisting under flight loads. Laser cut contest balsa and birch plywood. Complete hardware package including a 4" carbon fiber bell crank.
I intend to have everything ready for shipping by May 5th.
Eric
