  • July 18, 2025, 06:54:28 PM
Author Topic: supertigre NVA's  (Read 4176 times)
Offline Ken Burdick
supertigre NVA's
« on: February 08, 2017, 02:07:36 PM »
ST, needle valve assemblies are no longer carried by Tower....rats. Where can you find them other than 30.00 ea on flea bay
Offline Reptoid
Re: supertigre NVA's
« Reply #1 on: February 08, 2017, 02:10:30 PM »
       Don
       AMA # 3882
« Reply #2 on: February 08, 2017, 02:35:46 PM »
I'm fairly sure that the RSM clones have some sort of SAE thread, and wouldn't screw into a genie ST spraybar. I am a big fan of Randy Smith's NV Assemblies, but again, I'm pretty sure the NV is not going to fit ST spraybars. They will, however, bolt in where a ST spraybar did.  y1 Steve
Offline Ken Burdick
« Reply #3 on: February 08, 2017, 02:50:02 PM »
Thanks guys, I really appreciate it and likely would not thought of RSM. I'm retro fitting so no worries about the real deal. Steve knows I rarely do loops anymore but do like to go fast in a straight line. Getting parts for old ideas is getting more and more difficult.
http://flyinglines.org/kb.reworkingboris.html
Offline Walter Hicks
« Reply #4 on: February 08, 2017, 03:42:52 PM »
Enya 50-60 nva from shutterman $21 excellent quality nylon like Jett does not leak fast delivery
« Reply #5 on: February 08, 2017, 05:31:15 PM »
I use RSM no problems
Online mike londke
« Reply #6 on: February 08, 2017, 05:54:46 PM »
Jim Lee has them and I've had no issue with any I've bought from him.
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #7 on: February 08, 2017, 07:00:56 PM »
I was just doing some surfing around and found ST NVAs at a website called
ActivePowersports.com. I've never heard of this site, but these appear to be
actual ST NVAs, and at only $8.99 might be worth a try.
Offline Rick Bollinger
  • AMA 931589
« Reply #8 on: February 08, 2017, 08:08:29 PM »
I had bought one of Shttermans ST nva's when I received it it looked great but would not shut the fuel flow down enough to keep from flooding the engine. Shipped it back received a second one but the threads were messed up told him to just refund my money which he did no problem but then blocked me from buying anything from him on the bay. Too bad everything else I had bought from him was top notch. Maybe just a bad batch.
Rick Bollinger
AMA 931589
Online mike londke
« Reply #9 on: February 08, 2017, 08:51:21 PM »
« Reply #10 on: February 08, 2017, 11:39:22 PM »
I had this same problem with an RSM nva that I bought from SSW. It wouldn't bring my Magnum XL .25 to peak. After thinking about this a bit, I switched it over into an OS .46LA, where it worked just fine. Increased fuel consumption did the trick.  ;D Steve
« Reply #11 on: February 09, 2017, 06:29:27 AM »
There are three sizes of spray bars. I think this one is the smaller one but not sure. http://www.activepowersports.com/supertigre-22300825-needle-valve-assembly-g34-c-l-22300825/. Also over the years ST has changed the taper of the needle. The smaller bodies used a steeper taper. Mixing them all up can cause problems as described above.
 A few times I got DS mixed in with the ST and that caused all bad problems.
Offline eric rule
« Reply #12 on: February 09, 2017, 11:41:21 AM »
The threads on the ST needle valve assemblies manufactured for RSM are not SAE they are the proper metric sizes that have been used for years on the original ST needle valves.
In the very rare case where the needle will not shut off the fuel completely it is due to the needle taper not contacting the sides of the spray bar hole.  There is only one needle and it works in all three spray bars. Like all manufactured items they are made to a +- tolerance. Just pull it from the spray bar and sand off a bit of the sharp end of the needle. That will solve the problem.
Eric
Offline Lyle Spiegel
« Reply #13 on: February 09, 2017, 12:01:11 PM »
which version / Part number can be matched to Fox 35 Stunt?
Lyle Spiegel AMA 19775
« Reply #14 on: February 09, 2017, 12:55:45 PM »
Those are  the  15 size  ones, they used that one thru the top of the venturie on the  G51 CL
Has anyone actually  got any ST motors or  NVAs  from this group?
They show stuff in stock that has not been made in many years
« Reply #15 on: February 09, 2017, 12:58:46 PM »
NONE of them... unless  you either drill the venturie in the  FOX case  larger, as  many have done, or  file the sides of the  Needle body flat  so it does not  restrict the Fox venturi ,  if you do that  use  the  153  ST  NVA.
Or use the  OS  LA  NVA  with  a spacer on both ends
« Reply #16 on: February 09, 2017, 04:52:10 PM »
I bought severaL items  from them,  they took the money  said the items would be sent, then  refunded  my money on ST and OS  NVAs  plus  2 engines  and  did not ship anything at all,  so  not good
« Reply #17 on: February 09, 2017, 04:54:56 PM »
I have  ST NVAs
PA NVAs   best made anywhere in my opinion
Enya  spring type
Enya  hard  NVAs
OS NVAs
KK NVAs
I also have  new  PA  NVAs that have the fuel pickup/inlet and Needle on the same side, people love these for side ex muffler engines
Plus  PA remote  NVAs
and other
IN stock
Randy    Aero Product
« Reply #18 on: February 09, 2017, 08:54:48 PM »
Randy, I have a very long ST NVA that I believe was used through a carb for a 60 size tiger. It's longer than the other 3 ST NVA's. Have you ever seen one and do you have them?
in the  G21  and  ST  51  56  60   CL  NVAs,  they made 3  sizes  part numbers  end in 153 , 155, 161 , the  161 is the long one that  fits the  ST60
The plain bearing 29 35  takes the  short  153
the 29 - 46 G21  takes the  155
The  long one is the one for the  ST 60 single piece case engine ,and the large case  51 and 56
In needles  I have seen 3 lengths, but the  only very long needle  is a  Harry Higley long ST needle
there  are smaller  NVAs  for the  23  19  15  ST engines
also the New G51  NVAs  are the same size as the  small ones (153) from  years ago i think that number is  4290
I have not seen but  1 any longer, and it was not in an engine, so I do not know what it would fit?? maybe the  G60  or  71
« Last Edit: February 09, 2017, 10:59:29 PM by RandySmith »
« Reply #19 on: February 10, 2017, 06:29:30 AM »
I needed long needle valves for my two Bearcats. I cut off the end and soldered a piece if tubing between the two pieces. I have done that for years. The needles solder easily.
Offline eric rule
« Reply #20 on: February 13, 2017, 06:37:03 PM »
MM;
The taper on the needle is 7/8" long. In addition, the threads on the needle are long enough to allow you to screw the needle in much further. Once the diameter of the tapered part of the needle matches the diameter of the small spigot hole inside the spray bar it will shut off.
Theory is fine but reality is perfect every time! Give it a try then check it out by trying to blow through the spray bar. You will find that this will allow you to shut off the flow with no problem.
Offline dennis lipsett
« Reply #21 on: February 13, 2017, 07:52:17 PM »
For what it's worth I still have a package of Harry Higley ST  needle valves. Two to the package. I used these a lot years ago. They are about 4 inches long.
Dennis
« Reply #22 on: February 13, 2017, 09:49:40 PM »
http://www.smrpl.com.au/
If your in Aus. or with the current exchange rate , this guy ( Steve Rothwell ) does CNC Super Tigre type Nylon Gland NVAs ,
but He's into smelly diesels , not glows . So youd be wise to specify DIMENSIONS to hole from side & across intake ,
which shold be 'a' & '2a' we presumes .
20 Bucks Aus. & postage , if ive not got it wrong . Hald a dozen stock variations / types . Smaller ones might be 1/8 dia maybe.
thems Oliver Ones , std. theres the long needles .
« Last Edit: February 14, 2017, 05:06:40 PM by Matt Spencer »
