  • July 18, 2025, 03:34:58 PM
Author Topic: Super tigre X-40 line drawing with dimensions  (Read 1399 times)
Offline Scott Jenkins
« on: May 02, 2007, 08:05:10 AM »
Hi All,
Looking for a line drawing of a Super Tigre X-40 with dimensions.
Even just the bolt hole pattern layout would be nice.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Re: Super tigre X-40 line drawing with dimensions
« Reply #1 on: May 03, 2007, 01:53:21 PM »
BUMP
Scott Jenkins
AMA 43122
Offline Andrew Borgogna
  • Andy
« Reply #2 on: May 03, 2007, 06:48:01 PM »
Scott
I am assuming you are refering to the front induction rear exaust ABC engine from a few years back.  I think I know of a source for the information you are looking for.  You might give a call to Performance Specialties and ask for Dave Shadel.  Dave in the past was probably the formost expert on the ST x-40 on this side of the Atlantic.  He built them for Formula-1 racing, when they were no longer available he moved over to the Nelson engines.  I new Dave back then and he is a very nice person and should be able to answer your question.
Andy Borgogna
Andrew B. Borgogna
« Reply #3 on: May 04, 2007, 07:21:26 AM »
Andy,
Thanks, I will try to get in touch with Dave,
Scott
Scott Jenkins
AMA 43122
