  • August 04, 2025, 12:54:50 AM
Author Topic: Super Tigre V-45/51/56 plain bearing .  (Read 1405 times)
« on: February 28, 2021, 08:00:58 PM »
Theres not a lot of info / tests / anaylisis about, on these engines.
Stuff ive seen said the first lapped piston unfinned head versions ran hot / overheated ,
so were duely changed to twin ringed alloy piston and finned head .
Im particularly intrested in the crankshaft diameter / case shaft bore , Bolt head pattern / same as .60 B.B. ? , and cyliner outer diameter / case cylinder bore diameter .
Unless you waNNA DONATE ME AN ENGINE ! .  S?P
« Last Edit: March 01, 2021, 08:34:49 PM by Air Ministry . »
Offline Bill Morell
Re: sUPER tIGRE v 45/51/56 plain bearing .
« Reply #1 on: February 28, 2021, 11:05:56 PM »
I have all of those you have listed. The heads are not interchangeable with the BB engines of same displacement.  I have found 2 different versions of the 51. One has same size head as the 45 and the other is much larger. I'd post pictures but it's too much hassle on here.
Bill Morell
Vietnam 72-73
« Reply #2 on: March 01, 2021, 07:47:35 AM »
 I had two of those none bb .56 motors. I have never seen them with the ears on the case like in that picture.
Less powerful than the bb version but a very good runner. I hard one in a supper duper zilch
Offline Bill Morell
« Reply #3 on: March 01, 2021, 07:40:50 PM »
I have the muffler ears on 2 of the 45's and one 51.
« Last Edit: March 06, 2021, 10:41:31 AM by Bill Morell »
Bill Morell
Vietnam 72-73
