  • July 16, 2025, 07:24:06 PM
Author Topic: Super Tigre info needed  (Read 2045 times)
Offline Ron Cribbs
« on: August 16, 2017, 01:15:52 AM »
Guys, looking to source a couple ST stunt .35's
There seems to be some confusion out there as to which is is a stunt version and which is a combat version. I am assuming the C21/35 is the stunt and the G21/35 is the combat version. Is this correct?
I know the baffle is a dead giveaway for the stunt, but it's hard to tell from pictures. So are all C21/35's stunt and all G21's combat? I see a lot of engines up for sale claiming stunt with a G on the case and vice versa for the C's
Any insight would be most appreciated.
Ron
Online Bob Heywood
Re: Super Tigre info needed
« Reply #1 on: August 16, 2017, 06:39:24 AM »
Not quite so.
The Super Tigre C35 is a plain bearing design. They came with stunt timing and combat timing. There were also Perry Directional Ported (PDP) versions. The G21/35 is a ball bearing design. They also came in different states of tune as well as being set up for suction or pressure, front intake, rear intake, etc.
"Clockwise Forever..."
Offline Garf
    • Hangar Flying
« Reply #2 on: August 16, 2017, 08:41:03 AM »
The plain bearing model came in Combat and Stunt models. The combat had the same porting as the G21, the stunt model used a baffle piston and standard cyllinder porting.
« Reply #3 on: August 16, 2017, 11:25:15 AM »
The difference between the  plain bearing combat vs  Stunt version, was the  Piston. sleeve  and  head, The piston, of course has a baffle on it and the head is a different shape with a baffle clearance slot milled into it   I have seen PDP  combat versions, but  I personally  never saw a  PDP stunt version
Online Juan Valentin
« Reply #4 on: August 18, 2017, 04:08:03 PM »
Here is a couple of pics of the two ST.35 versions this are C35.I just bought another one in hope that is a stunt version.
« Reply #5 on: August 18, 2017, 08:46:48 PM »
Brian Gardner did some ABC ' Stunt ' 35 Super Tigre piston liners .
They go in the 21/35 Ball Bearing too . . . just have to take a disc grinder to the head for the baffle slot .  S?P
Tho I think he had heads done too .
I tried a 35C ( Combat ) and a 21/35 in the olde Phantom 52 span Magnum 25 / OS 25 sucker . FSR BB 25 did maybe 10 minutes ,
21/35 did 7 minutes odd , and 35 C , still tight in the shaft , did around 5 min - on the same tank full . Thats the ' flat top ' 35 C .
The 21/35s came with a Big & a Little  ( 9 mm & 3.2 mm Venturie ) The 21/35 unmuffled on a 9 x 6 theee blade sounded nice &
meanaceing unmuffled - in a damp steady 2 stroke .
The BIG Problem  >:( if it is one , is the ' Flat top ' piston set up has marginal ' sub piston induction ' right across under the piston
at T.D.C. ,
said to contaminate the case charge Muffled , & reduce Output discernably .
So the A B C set up is the easy answer . Tho I think most C-35-S were eaerly ' Hard Liner ' and last forever . Before the Liners were less hardened for easier Break In . A bit like the Rings in all but Early Chinese STs were less hardened - were told - for easier / quicker Break In .
Reports from 21/35 Users of the Stunt A.B.C. set up appear favourable . But Weight'd be similar to the 21/46 . So where does that leave you.
« Reply #6 on: August 18, 2017, 09:16:06 PM »
Of Course , the most important Thing , is to have the RIGHT STICKERS .
colours above need darkening considerably .
Anyone does some of these , theyd better send me some .
« Last Edit: August 18, 2017, 09:38:11 PM by Matt Spencer »
