  • July 25, 2025, 08:10:47 PM
Author Topic: Super Tiger needle valve  (Read 7121 times)
Offline Duke.Johnson
« on: May 19, 2013, 03:20:18 PM »
I need a new needle valve for a Fox .35.  It appears to have a Super Tiger NVA in it.  Where can I get a replacement and is there a certain type/size?  I'm ok buying the NVA if need be. Thanks for the help.
Re: Super Tiger needle valve
« Reply #1 on: May 19, 2013, 03:38:15 PM »
Try Jim Lee. He's in the Vendor's corner. His site has a PDF download, I saw a NVA for a Fox .35 listed just today.
Here's the link to his...
Jim Lee Machine Shop
http://stunthanger.com/smf/index.php?board=32.0
Offline david beazley
« Reply #2 on: May 19, 2013, 04:03:12 PM »
RSM has ST NVA's and needles listed on his site.
AMA # 2817
« Reply #3 on: May 20, 2013, 10:25:10 AM »
Are there different sizes?
Offline Mike Haverly
« Reply #4 on: May 20, 2013, 11:56:15 AM »
Or you could just get in touch with these folks.
http://www.foxmanufacturing.com/index.php?main_page=product_info&cPath=183&products_id=917
I have ordered from them before with success.
« Reply #5 on: May 20, 2013, 02:05:30 PM »
Hey Mike! I wanted to replace it with what was in it.  My son (the one that flies your old Oriental) was give an airplane that had an engine in it, but has to give the engine back.  Well, he broke the needle and I want to return it the way we received it.. With a ST needle.  We hope to see you at the Regionals.
Offline James D. Hayes
« Reply #6 on: May 20, 2013, 03:32:24 PM »
ST .51 works, I have one in my fox on my Ringmaster. Jim Snelson sells them at CLC. He's on down in the vendor section on this forum
Jim Hayes
AMA 988835
Just do it......
Offline ericrule
« Reply #7 on: May 20, 2013, 07:26:49 PM »
Hi Duke:
There are three sizes of St needle valve assemblies. These fit the ST51 (the smallest spray bar), the St .46 and the ST .60. we also supply replacement needles. You can find these items on our web site www.rsmdistribution.com Look under the engines subsection.
Eric Rule
Online Geoff Goodworth
« Reply #8 on: May 20, 2013, 07:46:26 PM »
Remember that the ST-style NVAs are 4mm OD (0.157"). They fit the Fox 35 crankcase but the Fox NVA is about 0.125" OD across the venturi—and so, reduces the venturi area much less.
Is the NVA that you are replacing constant diameter? If not, Randy Smith—and possibly others—supply an ST-style NVA that is necked down across the venturi to retain the stock venturi area.
« Reply #9 on: May 22, 2013, 09:10:11 AM »
Hi Duke:
Eric Rule
Hey Eric
Can you post a picture of your needles? Just to make sure I'm on the right page. Thanks.
Offline Balsa Butcher
  • High Desert Flier
« Reply #10 on: May 22, 2013, 10:02:54 AM »
If you already have the spraybar assembly installed and all you need is a Super Tigre needle Eric sells them separately. They are interchangeable, all you have to do is cut to the length you need for your model. 8)
Pete Cunha
Sacramento CA.
AMA 57499
  • High Desert Flier
« Reply #11 on: May 22, 2013, 10:56:51 AM »
Or if you don't want to wait for Eric to post - go to "shtterman"s E-bay control line store. Pictures are posted there. He is a reliable vendor and sells Hobby Fasteners/RSM items. This is the name RSM/Eric sells his ST NVA's under. Fox 35 NVA are listed as item "221224693718" on dabay.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline ericrule
« Reply #12 on: May 23, 2013, 08:37:37 PM »
Here's a picture of the STNVA
« Reply #13 on: May 23, 2013, 10:37:14 PM »
Thanks Eric. I'll get one after Regionals.
Offline Sport Pilot
« Reply #14 on: May 26, 2013, 06:17:20 AM »
Hi gents, by the way, which is the thread of the ST needle?
Thanks  H^^
