  • July 18, 2025, 11:18:22 PM
Author Topic: Super Tiger 35 - another one to identify!  (Read 1783 times)
Offline Robert Zambelli
« on: December 06, 2011, 06:55:11 AM »
Anyone know about this old Tiger?
Interesting that it's ringed.
It has G 21 and a large "V" cast on the bypass port.
Re: Super Tiger 35 - another one to identify!
« Reply #1 on: December 06, 2011, 10:36:14 AM »
Early two piece case. Rat and combat motor.
« Reply #2 on: December 06, 2011, 06:22:14 PM »
Ed is correct. I saw one run once, on a combat model. Made lots of noise, but only went a lap or two per start. Some sort of fuel tank issue; I'm sure it was on CC pressure.  y1 Steve
Offline George
  • Love people, Use things.
« Reply #3 on: December 06, 2011, 06:34:33 PM »
It's from the Mid fifties. My G21-35 is not ringed. It has front sleeve bearing, rear BB. It has a crankshaft pressure take-off on the bottom of the crankshaft.
Other engine is a G20-15 of the same era. It has two BBs. I think the BBs are plastic.
George
George Bain
AMA 23454
« Reply #4 on: December 07, 2011, 06:56:27 AM »
The first Rat Racer I ever had used this style G-21 35.  Looked brutish, swear you could swim in that venturi!
Offline Dan Bregar
  • Field Marshall
« Reply #5 on: December 07, 2011, 03:44:30 PM »
Ty
Ditto on replacing the bearings right off the bat.  The stock bearing had a brass cage with bent over tabs that let go pretty quickly.  Then you had nice little brass shavings all over.  A riveted steel cage bearing fixed the problem nicely.  :)
AMA 33676
Offline Chris Wilson
« Reply #6 on: December 07, 2011, 04:06:13 PM »
Crank case pressure from the nib under the intake Steve?
MAAA AUS 73427
« Reply #7 on: December 08, 2011, 05:52:31 AM »
I remember guys trying that nipple under the crankshaft, so timed pressure.   They wound up plugging it off and going to the back plate pressure using one of the backplate bolt holes. H^^
Offline W.D. Roland
« Reply #8 on: December 10, 2011, 02:33:43 PM »
Fafnir high speed phenolic retainer bearing is what we used for the rear of G21 crank.
Chunks of brass through the top end was never good for brass or engine.
Small bearings
check out drop down menus on links tabs.
http://www.ibsco.com/high-speed-bearings.php
David Roland
51336
