  • July 12, 2025, 08:10:57 AM
Author Topic: Super Staris Build  (Read 24462 times)
Offline Steve Fitton
Super Staris Build
« on: August 18, 2015, 01:25:35 PM »
Started a new plane this week.  Randy Smith Super Staris, planning on PA-75 for power.  As you can see, sheeted foam wing construction.
Offline jose modesto
Re: Super Staris Build
« Reply #1 on: August 18, 2015, 05:50:09 PM »
Steve. Does the granite table top have the top fuse carved into the surface. If so that's Pro Stunt.
Jose
« Reply #2 on: August 19, 2015, 09:33:53 AM »
Actually Jose its the bottom of a mold some guy gave me.  With the mold I can make molded balsa fuselages for Super Staris planes like hotcakes!!!
« Reply #3 on: August 27, 2015, 09:21:48 PM »
Sheeting the last stabilizer core tonight.
Offline Doug Moon
« Reply #4 on: August 28, 2015, 07:31:58 AM »
What Epoxy do you use?
Eeyore looks very interested...  Don't let that smile fool you he is making sure you comply to the BOM every step of the way!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #5 on: August 28, 2015, 11:12:55 AM »
Z poxy finishing resin.  I don't have any other true slow cure stuff around, and the z poxy cards out into a micro fine layer.  The glued surface gets a coat of nitrate first to seal it
« Reply #6 on: September 11, 2015, 08:09:39 AM »
Added and shaped leading and trailing edges.  Finished sheeted cores weigh the same as all my others, 4.5 oz each.
Offline Doug Moon
« Reply #7 on: September 11, 2015, 06:56:31 PM »
That is most excellent!
Doug Moon
AMA 496454
« Reply #8 on: September 11, 2015, 07:18:41 PM »
Steve:  Will it be ready to fly on September 26?   ;D
Offline James Mills
« Reply #9 on: September 11, 2015, 09:02:43 PM »
Nice one Doug.  It makes me a little sad that I actually spent perfectly good $ to go see that movie (both of them LL~).
James
AMA 491167
« Reply #10 on: September 12, 2015, 05:29:33 AM »
Scott, unfortunately I do not have Sparky levels of building speed. Maybe by next June. ...
« Reply #11 on: September 12, 2015, 06:21:14 AM »
Steve:
That's still faster than me.  I usually take at least 5 years to finish my planes!!  (Really!  Ask any of my flying buddies.  It's embarrassing!)
Eric Viglione
« Reply #12 on: September 12, 2015, 07:30:13 AM »
That is awesome Steve!!!! That weight is better than a lot I have seen, and in all probability close to ideal for such a big plane. Good job!
I tend to build in radical spurts... it's been a while since I made much progress, but after the electrician finishes up tomorrow and I can run my shop A/C, I think I will feel a radical spurt coming on.  ;)
EricV
« Reply #13 on: September 16, 2015, 05:03:09 PM »
Control system going in.  Morris ball links and standard phenolic bellcrank
« Reply #14 on: September 17, 2015, 12:31:47 PM »
Dry fit of wing panels and controls check.  The panels should get joined tonight.
Offline Matt Colan
« Reply #15 on: September 17, 2015, 12:34:29 PM »
I hope the shop Eeyore approves!! Looks good Steve! You're catching up to me quickly!
Offline Doug Moon
« Reply #16 on: September 17, 2015, 02:54:11 PM »
Eyore says, "You will need more than blue tape on that wing joint...."  and walks away.
Doug Moon
AMA 496454
« Reply #17 on: September 18, 2015, 07:58:29 AM »
Wing panels joined and after the epoxy cured the 2 oz fiberglass tape was applied with z poxy.
« Reply #18 on: September 18, 2015, 08:09:40 PM »
Cutting the .5 oz glass cloth for the reinforcement ellipses on the wing.
John Leidle
« Reply #19 on: September 19, 2015, 12:17:04 AM »
   Steve , did you make your own bell crank  ?
                    John L.
« Reply #20 on: September 19, 2015, 07:00:21 AM »
Put the glass ellipses on with z poxy.
John, It is a stock Morris phenolic bellcrank.  I've used the Morris ones for years and they are great.
« Reply #21 on: September 25, 2015, 11:49:14 AM »
Assembled tip blocks, tack glued on and shaped.
« Reply #22 on: September 29, 2015, 07:20:19 PM »
working on the tips, putting the leadout slider in.
« Reply #23 on: October 01, 2015, 02:23:35 PM »
Completed the inboard tip.  15 grams...
« Reply #24 on: October 05, 2015, 09:04:10 PM »
tips attached, getting ready to hinge the flaps...
Offline Crist Rigotti
« Reply #25 on: October 05, 2015, 11:50:33 PM »
Nice job Steve.
« Reply #26 on: October 09, 2015, 11:50:27 AM »
Cutting hinge slots and sanding flaps.  Fun stuff!!!!
Offline RC Storick
« Reply #27 on: October 09, 2015, 03:02:40 PM »
Just a tip Steve. On your next build if you sand the inside of the tips and all blocks smooth they are lighter and stronger. I always try to make the inside look as good as the outside. That's just a personal preference. Looking good is it done yet?
Offline Phil Spillman
« Reply #28 on: October 09, 2015, 07:15:23 PM »
Hi Steve, I've really been enjoying your play by play on this build! Sometime I'm going to come over and get a tutorial on just how to work on a foam wing from the bottom up so to speak!
Phil Spillman
Phil Spillman
« Reply #29 on: October 10, 2015, 07:02:29 AM »
How do you keep the paper from catching an edge or corner of the paper when sanding in something like a tip or top block?
Online Alan Buck
« Reply #30 on: October 10, 2015, 03:17:49 PM »
hi steve  what is the weight of your wing
ALAN E BUCK
Offline RC Storick
« Reply #31 on: October 10, 2015, 04:25:36 PM »
For inside the tip I CA sand paper to my finger. For outside blending run some masking tape over the wing and sand the outside of the tip to it.
« Last Edit: October 27, 2015, 11:15:45 PM by Robert Storick »
« Reply #32 on: October 19, 2015, 01:51:54 PM »
Slacked off for a few days....  here the Morris basswood horn boxed are being glued on and then sanded to match the flaps.
« Reply #33 on: October 27, 2015, 07:07:48 AM »
More done on wing details.  The root end of the flaps was glassed with 0.5 oz cloth, the inboard fixed tab was made, shaped and installed, and the outboard movable roll tab was made, hinged and the adjustment hardware assembled from Morris components.  I will sand the hard point for the wire flush with the wing and then start detail sanding the wing and surfaces in preparation for getting some nitrate on them.
« Reply #34 on: October 27, 2015, 07:10:19 AM »
working some on the sheeted foam tail as well.  Cut the cores apart into stabilizer and elevator sections, and joined the stabilizer cores with epoxy.
« Reply #35 on: October 27, 2015, 01:23:34 PM »
Wing ready to start nitrate.  14.2 ounces as you see here.
Offline Gordan Delaney
« Reply #36 on: October 27, 2015, 01:32:13 PM »
Steve,
Great job. looks good too!
Gordy
Offline Balsa Butcher
  • High Desert Flier
« Reply #37 on: October 27, 2015, 04:05:48 PM »
I like this build. Thanks for posting. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #38 on: November 05, 2015, 02:16:56 PM »
3 coats of nitrate on the wing at this point.  Been working on the stabilizer.  Installed the balsa/carbon fibre spar and then the balsa leading and trailing edges on the stabilizer.
« Reply #39 on: November 25, 2015, 02:18:49 PM »
Been busy with the mostly mundane process of covering the wing and flaps.  I used some old K&S SGM silkspan which works pretty well.  3 coats of nitrate over the silkspan and the wing is ready for installation now.  Still working on the stabilizer/elevators.  Just epoxied in the horn boxes this afternoon.
« Reply #40 on: November 25, 2015, 02:37:07 PM »
Nice work, Steve.
« Reply #41 on: December 07, 2015, 05:14:19 PM »
starting to dry fit the motor mount assembly to accommodate the 75.  The 75 is HUGE compared to the 65!!!  The mounts have to be a bit wider across the bearers to accommodate the engine case.
« Reply #42 on: December 07, 2015, 05:23:16 PM »
Hey, another great use for Hornady Bullets!  I love it!
« Reply #43 on: December 07, 2015, 06:12:55 PM »
Steve:
I am happy to see you moving up to a 75!  Congratulations!!
That 65 wasn't any good anyway.  Please send it to me for proper disposal.
Scott
Offline Doug Moon
« Reply #44 on: December 07, 2015, 10:19:57 PM »
Great build!
You are keeping me inspired to stay in the shop.
Doug Moon
AMA 496454
« Reply #45 on: December 08, 2015, 03:08:24 PM »
The tail assembly ready for nitrate, as you see it here it is 2.9 oz.  The tail for Dreadnought #2 was 3.0oz, the Rapier 3.0 oz, so they build pretty consistent.
Offline Monty Summach
« Reply #46 on: December 09, 2015, 03:22:08 PM »
Looking very nice - thanks for sharing.
« Reply #47 on: December 11, 2015, 07:23:16 AM »
Added aluminum pads to motor mounts, and am cutting out the front formers.  For the 75 the width of the motor mount assembly is exactly 2.25" outer edge to outer edge.
« Reply #48 on: December 14, 2015, 12:18:58 PM »
Silkspanning the stabilizer and elevators and finishing off the motor mount.  Time to cut fuselage sides next.
« Reply #49 on: December 14, 2015, 02:41:07 PM »
Hi Steve
its a little late, but what I do, is to slightly bevel the insides of the metal pads, this puts the bolt closer to dead center of the wood beams and makes the fuse slightly tighter and the crutch, many others do the same, I had many people do that when they swapped the 65 out for a 75, which is just a tiny bit wider.
Your build is looking great !  Keep up the great work
