  • June 25, 2025, 08:31:55 PM
Author Topic: Looking for some honest feedback  (Read 1943 times)
Mike Griffin
« on: December 08, 2009, 07:39:41 AM »
Guys I need some honest feedback from you all.  I have tried to offer a building service to our hobby that would fill a need and be in a price range that is affordable and fair.  So far i have not accomplished that goal and I am not sure if there simply is not a need for what I am trying to do or if it is just this horrible economy that we are all caught up in.  Let me explain what I have tried to do and then give me your feedback and tell me what you think.
I first tried offering an almost ready to fly Ringmaster.  The reason I picked the Ringmaster is because it is the most nostalgic of the CL planes and a lot of us learned how to fly with one.  There is only one kit manufacturer that I am aware of that is offering a laser cut kit of the Ringmaster and the man who owns that company is a good friend of mine and he has a great laser cut kit of that airplane.  I picked the Ringmaster for the reasons stated above and tried to go to market by "scratch" building it in a KD Semi-built form.  The wing was completely built with bellcrank installed.  The fuselage was completely built and the stab and elevator were hinged together and the rudder was cut.  Everything was finished sanded and all the flyer had to do was drill for the engine he was going to use, add a fuel tank, cover the wing, connect the pushrod, install the gear and wheels, paint it and go fly.  I even was supplying the gear, wheels, pushrod, control horns and all hardware needed.
I thought this was a unique offering and that our fraternity of flyers would like a Semi Built EZ assemble plane.  I was wrong. I sold about a dozen of them and then everything stopped.  The feedback I got from customers was all positive and there were no construction issues.  The main problem I ran into was the shipping cost.  In order to ship the plane with the wing built, it takes a BIG box and shipping and crating costs soared to $45.00 alone not counting the cost of the plane.  With labor and material costs I was selling the plane (without shipping figured in) for around $150.00 which I thought was reasonable.  The shipping cost brought it up to around $200.00.  I shpped by priority mail because it was the only service I found that could get the plane to the customer quickly and in good shape.  I had bad luck trying FEDX and UPS plus shipping was higher.
Recently, I thought if I could cut the cost of shipping, it might open up more of a market since the plane would be less money and I know right now a lot of people are strapped for cash including me.
In order to cut the costs, I thought if I could ship the wing parts KD, I could get the whole plane into a much smaller box and cut the shipping costs drastically.  So here is what I tried.  The leading edges of the old Sterling S1 Ringmaster are getting harder and harder to find and when you do get them most of them are not straight and the waste factor becomes an issue.  So what I started doing for the leading edges was forming the 1/16th on a buck then fitting the form over a piece of 1/8th balsa cut to size with forms glued to the 1/8th backer. It works great, is extremely light and strong.  I cut the ribs, put the trailing edges, center spar and cut to shape wing tips in the box, install the leadouts to the bellcrank, furnish the pre cut center planking and throw in a push rod.  In other words the wing comes in a KD state and does have to be built by the customer.  I do supply the pre cut wing tips.  The fuselage is cut with the wing cut out, hard wood motor mounts and plywood doulblers are epoxyed in and the whole fuselage is finish sanded.  I hinge the elevator to the stab and supply the control horn and cut the rudder.  I still will supply the gear and wheels and all the hardware.  I can fit the whole plane into a much smaller box and shipping costs go way down.  I can sell this plane for much less because the labor is a lot less since I do not build the wing.  I could actually sell this plane for under $100.00 plus shipping cost which should run somewhere around $15.00.
I still got no reaction from offering the plane (Ringmaster) in this form either.
Is is because I have just been offering a Ringmaster?  If so I have plans for a lot of different profile type planes such as a Twister (fancherized or regular), Flight Streak, a profile version of an Adams Special, Forerunner, Nobler, etc etc.  The prices would vary a little because of the amount of material I would have to use in a larger profile or a smaller plane like a Ringmaster Jr. would bring the price down.  You all know that plans are available for just about any plane out there either profile or full body.
Is the economy, is it I have not offered any plane but the Ringmaster, is it because no one needs or wants a service like this?
If you have taken the time to read all this, I need your feedback.  I am retired and am not trying to make a living doing this.  I would like to just make enough to support my habit which is my love of building a flying model airplanes.
If there is no need or demand for what I am trying to do, I see no reason to keep spinning my wheels and getting frustrated.  I can build for myself and be happy although my wife thinks I have way too many planes.  We all know you can NEVER HAVE TOO MANY PLANES.
I want to thank you in advance for your constructive help and input.
Mike Griffin
Re: Looking for some honest feedback
« Reply #1 on: December 08, 2009, 07:59:28 AM »
 I think your problem is you are trying to compete with ARF's. An ARF is very cheap and easy to build so a lot of people that would be potential customers for you could just as easily and cheaply buy an already covered ARF. An ARF Vector is only around $100. Dad builds Planes for people all the time but these people call and order a specific plane and every one is custom to what that person wants, engine, controls, etc. He charges considerably more too! Dad is also know to be a very good builder, so take all these things into consideration.
 I think you should keep at it though, maybe try a different plane though. A little bigger maybe. Try a Twister or a Banshee.
Derek
Offline Bill Hodges
« Reply #2 on: December 08, 2009, 11:11:51 AM »
Mike:
Personally, I think you are on the right track.  That is why I and my friend, Joe, both have orders pending with you.
Derek may have a good point though.  Maybe a different airplane might draw a little more interest, particularly with the younger folks.  It may be that the younger people just getting into CL would be more interested in something a little "more modern".
I'm an old guy.  I ordered the Jr. Ring for nostalgic reasons.  It was my first airplane many, many years ago.  I am also aware of the high quality of your workmanship and that did play a big part in my decision to order from you.
I also believe that the current economy has to have an adverse effect on a venture like yours.
Hang in there and keep trying.
Bill Hodges
Bill Hodges
AMA 12450
Offline Phil Coopy
« Reply #3 on: December 08, 2009, 12:24:43 PM »
Mike,
I think one thing hurting you is that in this particular venue of the model airplane hobby, nearly all of the flyers are also avid builders. I wouldn't buy an ARF/ARC not because of the quality, but simply because I would lose the fun in building it. If I was a top of the heap flyer, with new builder rulings, I might have someone build a competition plane for me, but most of us are not in that class yet so we have to build our own bricks. n~
Phil
« Reply #4 on: December 08, 2009, 04:27:31 PM »
I'd go with a P38 big enough for a couple of .19s ;D  In Nam they had a similar plane to the p38, not sure what it was...call sign Black Pony! H^^ Here it is I believe, an OV10
« Last Edit: December 08, 2009, 04:47:59 PM by John Stiles »
Mike Griffin
« Reply #5 on: December 08, 2009, 05:08:09 PM »
I appreciate all the good feedback guys.  Dale  KD means Knocked Down.  I am sorry.  I have used that term in my previous life career and made a bad assumption that everyone would know what it meant.  Sorry about that.... Were you kidding or do you really want a Ringmaster?
Mike Griffin
« Reply #6 on: December 08, 2009, 05:13:44 PM »
Hey Derek
I am well aware of your dad's building reputation and he is a great one as well as a a good man.  Thanks for your input and everyone has given me some good points and ideas to consider.  I am retired and have the time to do it and I am going to hang with it.  I spent a lot of time talking with Tom Dixon and Tom Morris last year at our show in Perry and they have given me some good advice also.  And like you said, they get a good but fair price for their work.  I think i am going to have to open my offerings up to more planes for sure.  I was doing profiles because they are easier to ship but I can certainly do full bodied planes too if I need to.  I am going to build a few for the Perry SHow and see how that goes too.
Thanks to everybody for their ideas.
Mike Griffin
« Reply #7 on: December 08, 2009, 05:17:28 PM »
Hi Bill Hodges
Thank you for the kind words.  I of course will have you alls planes ready at the show and I know you will be pleased.  I am just trying to make enough to keep supporting my habit of making model planes and keep my wife happy when I dont use household funds for purchases. LOL...you know how that goes.  I am going to start offering more types of planes I guess.  That seems to be one of the recurring things I hear .   Derek made a good point about that.  Looking forward to seeing all of you at Perry.
Offline Serge_Krauss
« Reply #8 on: December 08, 2009, 07:39:26 PM »
I don't know whether sales would increase, but the "Circus King" was popular and is not currently kitted by anyone. Possibly some old models like this with slightly thicker wing sections, while not classic or OTS legal, might prove attractive to some. Overall, the idea of producing something with nostalgia or eye appeal is not bad. It needs to be the best combination of being esoteric, easy to build, nostalgic, and/or beautiful, probably the most common selling points. The market is not large, but the hobby needs supporters like you, willing to contribute to the cause. We are grateful to Walter, Eric, at least threeToms, Bill, Bob, Larry...and those I didn't think of this moment for their efforts, good products and respect for heritage, as well as our fine modern designers, some of whom fall in both lists. Joining this list is perhaps daunting, but worthwhile. However, the market is modest, and we don't want to see good products/people squeezed out either. ' obviously not an easy choice. I don't build many kits, but I'd probably like to build - from a kit - the one pictured below, since the effort is less than for building my own or what is currently status quo.
SK
Mike Griffin
« Reply #9 on: December 08, 2009, 08:23:55 PM »
Serge I appreciate the support and Ideas.  I have to be truthful here and say I was not aware of the Circus King but I am sure the plans are floating around somewhere.  Tom Dixon has hundreds of plans and I can contact him and see if he has it.  I am actually working on building a CL version of the Ercoup and have the plans.  I am seriously considering building a prototype.
My thanks to you and everyone here for taking the time to respond to me.  I take great pleasure in building and contributing what I can to this hobby.  If i were independently wealthy (that will never happen) I would build these planes and give them away to people who wanted to learn to fly them but could not afford to do so.
« Reply #10 on: December 10, 2009, 11:29:07 AM »
Contact John Ashford here on the forum via PM.  I think he does building of planes for people.  He might give you some help on how to really get started and what to charge.
« Reply #11 on: December 10, 2009, 07:36:23 PM »
Ya gotta admit; at least...it makes a great desktop background.  ;D
« Last Edit: December 11, 2009, 06:01:22 AM by John Stiles »
