  • June 29, 2025, 05:39:16 PM
Author Topic: ...Tip weight...  (Read 1634 times)
Offline Bootlegger
...Tip weight...
« on: September 19, 2007, 08:15:45 AM »
 Guy's I posted this same question on the other web about tip weight in a Bucaneer 740 that is under construction.
  I'm thinking about 5/8 oz permanent weight with a tube to add weight.
 What do you guy's suggest ??
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ...Tip weight...
« Reply #1 on: September 19, 2007, 08:25:04 AM »
Start with a weight box in the outboard tip big enough to hold at least an ounce of weight.  Then start with at least 1/2 ounce and go up or down from there.  Have fun,  DOC Holliday
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: September 19, 2007, 08:29:32 AM »
Repeat after me..... I will never ever again install any perminate tip weight in a CL airplane other than trying to get the heaviest wood in the outboard wing panel.
Offline Bootlegger
« Reply #3 on: September 20, 2007, 11:18:17 AM »
 #^ As of yet I haven't installed the wing yet and I don't remember if I weighed the ribs or not. I do try to have all the heavest wood in the outboard wing anyway.
  I am gonna check the wing with L/O's installed and see what wing is heavy. Then I can proceed from there..
 I sure do thank "youse guy's" for the help and suggestions...
  Ty we sure are lookin forward to the contest here next month, and lookin forward to seein you too... n~ n~
Gil Causey
AMA# 6964
« Reply #4 on: September 21, 2007, 07:47:22 AM »
Hi Gil,
A Buc 740?  IIRC, that one is close to equal span wings, right?  I put 1/2 oz. in our permanent and had no problems.  Added a touch during trim flights.  I have built *some* weight into almost all my builds (plus the adj. box) and, so far, I have added weight to the box each time.
I don't understand why those would say not to do it. ???  And remember, I like planes to feel pretty light on the end of the lines, so I fly with the LEAST amount of tip weight I safely can, and fairly tail heavy, all of which lessens the pull.
