  • June 21, 2025, 04:11:12 AM
Author Topic: IC Tricks with an Electric Airplane  (Read 2920 times)
« on: October 01, 2014, 11:17:27 PM »
I have been flying electric stunt for awhile now, and I've finally figured out how to do some of the things we were able to do with IC engines, such as the burst of speed from running lean at the end of the flight, which is nice for the F2B one-lap landing descent from five feet.  I got a couple more tricks to work this afternoon.  For example, if you have the right settings on the electronics, you can get your motor to "come on the pipe", as Mike Haverly put it, after takeoff.  The other trick is even more bizarre, but it works, and I have a witness.
I have six-cell Thunder Power batteries, which are a funny shape.  The six cells are stacked vertically, so the battery sits tall in the plane.  The negative power lead is at the extreme bottom, outside corner of the stack.  The positive power lead is at the extreme top, outside corner.  After five and a half minutes or so of running, I can do a kill loop, just like with an IC engine.
You guys think I make this stuff up, but if you go to the Salem contest this weekend or the Madera contest later this month, I'll show you.
Edited to respell "cells", the misspelling of which a spell checker wouldn't have caught.
« Last Edit: October 02, 2014, 12:11:51 PM by Howard Rush »
Offline tom brightbill
Re: IC Tricks with an Electric Airplane
« Reply #1 on: October 01, 2014, 11:21:40 PM »
Sounds TUTish to me. ;D
AMA 34849
Offline Steve Hines
« Reply #2 on: October 02, 2014, 12:26:31 AM »
I seen my first kill loop on a electric last weekend. but it was on a outside and then we had to look for the battery. :) :) :)
Offline Igor Burger
« Reply #3 on: October 02, 2014, 12:29:53 AM »
Strange, I do much better landings with electric just because it stops cleanly and does not jump up and down because of power variation at the end :- )))
... I can even manage it to stop it up wind or down wind or where ever I want ... just by proper using stopwatches  ;D
Offline Keith Renecle
« Reply #4 on: October 02, 2014, 02:29:56 AM »
Sounds to me like the battery is pulling the plug out in the loop?? #^ Hopefully it is not flying out the bottom of the plane! I've had that before on one of my profile stunters when I did not strap up the velcro properly.........not a good idea!
Keith R
Keith R
« Reply #5 on: October 02, 2014, 06:48:44 AM »
I have six-cell Thunder Power batteries, which are a funny shape.  The six sells are stacked vertically, so the battery sits tall in the plane.  The negative power lead is at the extreme bottom, outside corner of the stack.  The positive power lead is at the extreme top, outside corner.  After five and a half minutes or so of running, I can do a kill loop, just like with an IC engine.
You could just run a piped IC setup and these things would not seem so spectacular.  ;)
Derek
Offline Doug Moon
« Reply #6 on: October 02, 2014, 08:53:07 AM »
A hard loop shuts down your system?  Or is it the timer??
If a hard loop shuts down the system are you sure that is a good thing......??
« Last Edit: October 02, 2014, 09:53:57 AM by Doug Moon »
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #7 on: October 02, 2014, 09:08:31 AM »
Is the balance connector rigged for uniflow?
« Reply #8 on: October 02, 2014, 09:19:16 AM »
It happens right after the little man inside yanks out the vomit bag!  LL~ LL~ LL~ LL~ LL~
« Reply #9 on: October 02, 2014, 12:06:09 PM »
A person who can do his square eights upwind should be able to land anywhere.
« Reply #10 on: October 02, 2014, 12:13:26 PM »
Mr. Walker's battery did that once, with a disappointing lack of fire and smoke.
« Reply #11 on: October 02, 2014, 01:13:32 PM »
I once wondered that with my OS .40VF after the first loop of a clover at the Nats.  So far the electric system hasn't shut down in a loop before 5:37 into the flight.  I plan to have a green light come on at 5:37.  One could probably rig a float in your fuel tank to do the same.  It could turn on a light like the low-fuel light on the Prius, which tells you when you have 15 seconds of fuel left.
« Reply #12 on: October 02, 2014, 01:15:28 PM »
Mr. Igor Burger's timer takes care of the uniflow function, Tim, along with the 4-2 break.
« Reply #13 on: October 02, 2014, 01:19:11 PM »
Howard; Us Old Time stunt ignition flyers need your expertise. If we could kill the battery to ignition with an inside loop it would be great. Sparkers will not die completely upon an inside loop. Or is this just more Rush trickery that won't work for anyone else. Yo best come clean on this one.
« Reply #14 on: October 02, 2014, 01:31:24 PM »
See Tim Wescott, although a MEMS rate gyro on an ignition Old Timer seems peculiar somehow.
« Reply #15 on: October 02, 2014, 01:33:33 PM »
Silicon MEMS gyros are just made out of sand and oil, ultimately.  They had sand and oil in 1952.
Offline Paul Walker
« Reply #16 on: October 02, 2014, 01:38:25 PM »
Yes......
And I can do a loop kill without the TUT!
See you in Salem for the loop kill contest!
« Reply #17 on: October 02, 2014, 02:38:42 PM »
I'm sure you can do it.
It will work terrific,
If you fly an airplane
Paleolithic.
« Reply #18 on: October 02, 2014, 03:15:53 PM »
Well Bummers.
       We can't be running that modern poof in our old Sparky planes. I guess what we really need is a timer that will shut off at about 6 and 1/2 minutes. All of the old Free Flight timers that I know of only worked for like a minute or so.  That way we would not have to worry about which fuel to run or how much. Just fill it up and let her go. Guess I will have to work on that. There is a world of difference in run time between gasoline and alky fuel, and when running gasoline a click or two on the needle makes a bunch of difference.
Offline Doug Moon
« Reply #19 on: October 02, 2014, 03:21:36 PM »
How does it work? I have seen and and performed some pretty insanly hard stuff with helicopters and it never shuts down.  If it did it would suck very badly and cost a ton of money...
Doug Moon
AMA 496454
« Reply #20 on: October 02, 2014, 03:27:00 PM »
I could do that for you, too, but it'd still be a modern microprocessor, even if there's no MEMs sensors.  I could do it with vacuum tubes, but you may need to build a plane that's (ehem) a bit bigger than usual.
Check with Texas Timers.  While engine timers aren't going to do it, there may be some mechanical DT timers that run that long, and you could easily rig one up to actuate an engine cutoff.
Edit:
Or use an old-style DT cord, which you could make any length.  Can you still get that stuff?
« Reply #21 on: October 02, 2014, 03:38:26 PM »
Thanks Tim;
  I forgot about the Texas Timers DT timers. All we have to do is break the lead to the points. Thanks again. I might come up with something that actually works. LOL
« Reply #22 on: October 02, 2014, 04:52:12 PM »
Nobody except me seems to understand Howard"s shut-off system.  Simple.  The Centrifugal force in a loop pushes the protons and neutrons to the bottom, while the electrons, being somewhat lighter, remain at the top.  since these particles cannot function without being in close proximity to one another, the battery "starves" for current (which, after all, is simply the movement of electrons).
F.C.
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« Reply #23 on: October 02, 2014, 05:03:17 PM »
Batteries have juice in them, Howard has learned to work the juice.
AMA 77370
Offline John Rist
« Reply #24 on: October 02, 2014, 05:18:08 PM »
The real answer is that the battery is low on charge at the end of the flight.  The extra load from the loop drops the voltage below the cutoff voltage of the speed controller causing it to turn off.
PS the KR timer already does all this fancy stuff.
Offline Steve Fitton
« Reply #25 on: October 03, 2014, 06:06:04 AM »
Didn't Howard's RoJett 65 do all this stuff?
« Reply #26 on: October 03, 2014, 07:05:49 AM »
The important thing to remember about any electronic circuitry is to not let the smoke out. It is almost impossible to put it back in.
Offline Doug Moon
« Reply #27 on: October 03, 2014, 10:07:28 AM »
Will the log report show this?
I know Howard and team run their batties down around 20% before the end of the flight.  Is that correct Howard?  20% of the charge is not enough left to stay over voltage limits for one loop?  I have killed a couple of batteries along the way :( running them too low while pushing out flight times on my helicopter but they were still able to do the "stuff" without shutoff...  This is interesting...
Doug Moon
AMA 496454
« Reply #28 on: October 03, 2014, 10:38:49 AM »
I believe that most ESCs in helicopter mode won't shut down the motor to save the batteries.  In airplane mode that's not the case.  I'm not sure how that affects ESC settings when you're flying 'lectric, because I fly slime.
Offline Dane Martin
  • heli pilot BHOR
« Reply #29 on: October 03, 2014, 11:03:32 AM »
I'd have to say negative on that one. all of my heli's are set to shut off the motor at  3.2v per cell. you can adjust the shutoff and warnings to several different levels. all of the good stuff anyway. i only use castle esc's
Offline Igor Burger
« Reply #30 on: October 03, 2014, 01:23:06 PM »
Only in case that the circle is not built on rocky mountains grass field :-P
John Leidle
« Reply #31 on: October 03, 2014, 08:26:56 PM »
  This year in Muncie I did square 8s into the wind both Wednesday & Thursday.. still have to land in my favorite spot .
