  • July 14, 2025, 12:53:52 AM
Author Topic: Super 'Phatic  (Read 2543 times)
Offline peabody
Super 'Phatic
« on: December 07, 2020, 05:20:46 PM »
Is this stuff what they advertise it?
https://www.towerhobbies.com/product/super-phatic/DLMAD21.html
Peabody
Dennis Leonhardi
Re: Super 'Phatic
« Reply #1 on: December 08, 2020, 01:22:07 AM »
Peabody
Haven't used that but their products seem to be great.  I've used their "Foam Safe" glue on EP Foam RC planes and love it.
Dennis
Offline david beazley
Re: Super 'Phatic
« Reply #2 on: December 08, 2020, 06:44:35 AM »
I have used it and kinda like it. It flows about like CA and penetrates well. Sets up slower than CA but faster than Titebond or Elmers.  Doesn’t really set up hard, remains somewhat flexible. Doesn’t sand quite as well as Titebond 1.  It has its uses but IMO not a do all end all glue.  Free flight guys like it in some applications as Ambroid is gone and Duco formula has changed over the years.
AMA # 2817
Offline John Park
  • Agricola
Re: Super 'Phatic
« Reply #3 on: December 09, 2020, 04:49:03 AM »
I've used it a lot, chiefly for wing spars - assemble ribs and spars dry, check everything's lined up, and add the glue using a fine nozzle.  It wicks into the joints better than anything I know except cyano, and I feel more confident using it because it takes time to set, giving you an opportunity to spot and correct any line-up issues.
Offline peabody
Re: Super 'Phatic
« Reply #4 on: December 09, 2020, 05:30:45 AM »
I ordered some from Amazing
Re: Super 'Phatic
« Reply #5 on: December 09, 2020, 04:28:05 PM »
Thanks.  Got me some.
Howard
Through-hole man trapped in a surface-mount world
Re: Super 'Phatic
« Reply #6 on: December 28, 2020, 04:04:06 PM »
Glue arrived solid.  I got a refund.  Looking at Amazon reviews, I see that this is a common complaint.
Offline Steve Fitton
Re: Super 'Phatic
« Reply #7 on: December 28, 2020, 04:44:17 PM »
That's not good.
Bob Hunt suggested Titebond 3 to me.  It's worked well so far.  I like how thin it is and it doesn't grab right away which is helpful.
Re: Super 'Phatic
« Reply #8 on: December 28, 2020, 05:03:43 PM »
Howard you got the child-proof /spill proof version.
Re: Super 'Phatic
« Reply #9 on: December 29, 2020, 06:46:32 AM »
I must not have that many applications where I need to use wicking since I've had the same small bottle of SIG CA in my refrigerator for a few years now.
Mostly I use Gorilla White aliphatic cut with about 10% water or Weldbond cut with 10% ammonia for better wood penetration when sticking stuff together.  I keep it mixed in some small plastic bottles with needle (very large needle) applicators to use ala Tom Morris' recommendation.
Offline bill bischoff
Re: Super 'Phatic
« Reply #10 on: December 29, 2020, 07:29:34 AM »
I worked in a hobby shop for 23 years. When a water based glue such as this was exposed to freezing temperatures, this would typically happen. Apparently a few hours in the cargo hold of a jet was ok, but overnight in the truck at sub-freezing temperatures was enough to ruin it. We returned lots of hard RC56 and Formula 560 canopy glue during the winter.
« Last Edit: December 29, 2020, 04:01:16 PM by bill bischoff »
Offline Akihiro Danjo
Re: Super 'Phatic
« Reply #11 on: December 30, 2020, 09:09:27 AM »
I had ever used that stuff but I don't like it very much. Because it dries a little gummy and not very strong for C/L use though it would be OK for F/F use.
Aki
Re: Super 'Phatic
« Reply #12 on: December 30, 2020, 01:38:31 PM »
   I have the same problem with all of the alternative aliphatic glues, and gorilla glue - they never get very hard and that makes them impossible to sand, they deflect while you are sanding, then spring back. Titebond II is particularly bad about it, it's like liquid rubber.
   I like original Titebond and Elmer's Carpenter's wood glue over any of the new ones. Drying hard is not a problem, silicon dioxide sandpaper will still go through it like butter. Pica and the old white Luthiers glue also dried completely rigid.
   I have the same issue with SIGMENT/Duco, to a lesser degree- too much plasticizer. I am sure it is tougher that way, so it might work better as an adhesive by being tougher, but that also makes it difficult to sand.
