  • July 01, 2025, 10:49:42 AM
Author Topic: Another way to minimize dust in your shop  (Read 2321 times)
Offline Robert Zambelli
« on: September 07, 2014, 06:10:42 AM »
A few years back, I wrote an article describing how to collect the dust generated by electric saws, sanders and the like.
Anyone interested in seeing it?
Offline john gunn
Re: Another way to minimize dust in your shop
« Reply #1 on: September 07, 2014, 06:20:37 AM »
yes,give details of how it is set up and where to purchase parts,thanks
Offline Douglas Ames
« Reply #2 on: September 07, 2014, 06:53:20 AM »
Central Shop Vac system?
AMA 656546
Offline Larry Fruits
« Reply #3 on: September 07, 2014, 09:31:50 AM »
Yes.
 Larry
Offline Bill Morell
« Reply #4 on: September 07, 2014, 12:28:55 PM »
Sounds good to me!
Bill Morell
Vietnam 72-73
ron young
« Reply #5 on: September 07, 2014, 01:15:54 PM »
Me to
« Reply #6 on: September 07, 2014, 01:48:50 PM »
OK, here goes.
Please let me know how it turns out and if it is helpful.
You can get all the materials at the local hardware store and Walmart.
Online Crist Rigotti
« Reply #7 on: September 07, 2014, 05:32:38 PM »
OK, here goes.
Thanks Bob.
Offline WLGeorge
« Reply #8 on: September 07, 2014, 06:11:27 PM »
Of course I am interested! Anything that builds my knowledge base helps!!
Offline afml
« Reply #9 on: September 07, 2014, 06:56:36 PM »
Many thanks Bob! #^
"Tight Lines!" H^^
Wes
Wes Eakin
« Reply #10 on: September 07, 2014, 07:05:51 PM »
Spraying water all over IS getting tiresome!  :P Steve
« Reply #11 on: September 07, 2014, 07:26:57 PM »
Thanks Mr. Z,  I now have a copy printed off for use when and if I ever get around to redoing the shop.
« Reply #12 on: September 08, 2014, 05:21:26 AM »
Very cool!  H^^
« Reply #13 on: September 08, 2014, 06:21:15 AM »
Hi, Guys - thanks for the compliments.
Implementing this dust collection system and the previously posted "mega bench", I have managed to keep my shop remarkably dust free.
As you may have noticed, at the far right is a small jigsaw.
That has since been removed (the bandsaw does it all) and replaced with a long flexible hose with a vacuum cleaner attachment. This allows me to pick up any stray sawdust or small pieces that may have escaped.
Please let me know how this works out for you.
Offline Phil Spillman
« Reply #14 on: September 08, 2014, 07:45:12 PM »
Hi Bob, Many thanks for another creative and imaginative invention and solution to a universal problem! This sure would be a great topic for one of your Control Line World columns!
Phil Spillman
« Reply #15 on: September 09, 2014, 12:06:26 AM »
Thanks Bob. Great idea.
 Larry
Offline 55chevr
« Reply #16 on: September 09, 2014, 05:27:39 AM »
Did you make any provisions for grounding the PVC?
Joe Daly
Offline WLGeorge
« Reply #17 on: September 09, 2014, 09:08:21 AM »
Thanks.  I really liked the flapper idea which works better than my empty soup can over the end design..  After about 5 years of use my shop vac is in dire need of replacement.  Last year I did finally wire the shop vac to come on when I turn on the main switch that feeds power to everything on the bench.  A vast improvement.
Offline Phil Krankowski
« Reply #18 on: September 09, 2014, 07:58:09 PM »
Yea, that can hurt.  I have been there blowing insulation, as well as using my 10 ft "wand" cleaning my vaulted ceiling.
I suspect that simply using metal brackets at regular intervals, and grounding the bracket would be adequate.  An exterior wrap of bell wire would be near complete protection.  The whole "Leyden jar" effect of not grounding the inside is probably overrated, but a charge could build up between teh inside and outside that is enough to hurt, but probably not injure.
Ever consider plumbing in a trash can to make emptying the system easier?
Phil
Offline KenP51
  • K Pitts
« Reply #19 on: September 09, 2014, 08:28:51 PM »
That is really excellent Thanks Bob
But as for me and my house, we will serve the Lord
