  • July 20, 2025, 03:06:32 PM
Author Topic: Sullivan ProFlex Fuel Tubing  (Read 2072 times)
Offline Steve Scott
« on: March 21, 2018, 09:54:24 AM »
I picked up a 2' length of this yellow-colored tubing.  Allows you to use either methanol-based glow fuel or gasoline-based fuel.  Diesel, I don't know but this stuff isn't cheap.
I've had an issue with the silicon tubing we've used for years when plumbing our smaller plastic tanks for uniflow clunk setup in that the thicker walled silicon was pretty inflexible.
Anyone tried the Sullivan ProFlex product yet?  It appears (initially) a bit more pliable.
EDIT:  Added product link
http://sullivanproducts.com/product/s211/
« Last Edit: March 21, 2018, 10:42:42 AM by Steve Scott »
Offline George Albo
Re: Sullivan ProFlex Fuel Tubing
« Reply #1 on: March 21, 2018, 10:32:09 AM »
I haven't tried it, but if you end up liking it, you can buy it here at a substantial savings:
http://www.usplastic.com/catalog/item.aspx?itemid=90245&catid=864
Offline Steve Scott
« Reply #2 on: March 21, 2018, 10:45:56 AM »
Pretty sure the Tygon is not the same stuff.
Offline Skip Chernoff
« Reply #3 on: March 21, 2018, 11:22:30 AM »
I have used it and it works great!
Offline katana
« Reply #4 on: March 21, 2018, 01:17:08 PM »
If it is Tygon then it suffers eventually with unleaded gas - goes hard and brittle - seemed ok with leaded gas on our Dragbikes!
« Reply #5 on: March 21, 2018, 05:09:45 PM »
It's most likely a modfied urethane tubing.  That is fuel proof for both gasoline, diesel, petroleum oils, and alcohols.  Urethane is generally pretty stiff for fuel line.  Or it may be a variant of Viton, which is a fluoroelastomer(fluorinated synthetic rubber)-.  Viton can be made pretty soft and is resistant to almost all solvents and oils except alcohols.  I've used Viton for fuel line and it holds up well, since we don't keep it soaking in fuel.
Viton is just 3-5 times the cost of anything else and not readily available.
« Last Edit: April 20, 2018, 02:09:37 PM by phil c »
Offline Walter Hicks
« Reply #6 on: March 24, 2018, 07:23:22 PM »
Phil I agree this stuff was too stiff for sure in a clunk tank.
« Reply #7 on: March 25, 2018, 03:45:15 PM »
It's definitely not Urethane based and it's very flexible.  My guess is that it's a flouroelastomer based tubing, maybe similar to viton!  It's very thin walled and tough but very flexible.  I've used it in plastic tanks for some time with great success!  It seems to last forever!  Expensive but good stuff!
« Reply #8 on: March 28, 2018, 05:19:15 PM »
     The ProFlex line is definitely not Tygon or anything like it. It's more like some sort of rubber and much more flexible than silicone, almost as flexible as good old  gum rubber - but presumably won't fall apart or get sticky.
      The two question marks  are whether it can stand up to touching an exhaust header, and whether or not it "welds" itself to metal fittings like silicone
