  • July 16, 2025, 05:43:39 AM
Author Topic: Suggestions please  (Read 1585 times)
Offline Bootlegger
Suggestions please
« on: November 20, 2020, 04:58:35 PM »
 Need ideas /suggestions for a five gallon rack to be able to pour from a 5 gallon container to mix stunt fuel...
  Any ideas/suggestions.. Obliged       y1 y1 y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dan Berry
Re: Suggestions please
« Reply #1 on: November 20, 2020, 06:08:22 PM »
Pour from the top of the can.
Offline Gerald Arana
« Reply #2 on: November 20, 2020, 06:56:52 PM »
This is what I did: Lay your 5 Gal container on a table waist high with the opening (spout) up. Simply roll the can a few inches with your other container under the spout. When you get the desired amount roll it back up. Simple! y1
Jerry
OBTW: Nitro is the heaviest ingredient in fuel. Measure it by volume.....
« Reply #3 on: November 21, 2020, 02:24:31 PM »
Simple, go buy a pump for the container.  They have them for cars, mowers and what ever else you can think of. S?P
Offline Paul Wescott
« Reply #4 on: November 21, 2020, 04:42:16 PM »
What Doc said.  Fuel pump.  Plus...
Modify the lid (or A lid) for one of those fancy fuel fittings; fuel line with bronze filter clunk inside the 5gal can.
If you’re going to mix a lot: Electric (Boxxer?) pump on the outside.
If you’re not going to mix a ton, or if you want more precise control: Six-shooter manual pump.
Fold up a rag / shop towel and put it under the back edge of the can to tilt the can forward.
When the can gets lighter shake it to make sure the clunk is in the deep spot under the cap.
Another possibility would be to modify a cap by adding a small brass spigot and as Jerry suggested, lay the can on it’s side, and let gravity do the “heavy lifting”.
PW
Offline Oldenginerod
« Reply #5 on: November 21, 2020, 05:44:08 PM »
I personally wouldn't install a pump or modified lid.  I would support Jerry's idea of rolling the drum to get the content out.
The drum should be kept tightly capped to prevent moisture migrating in.  My 20 Litre drum of Methanol has a fitting at the bottom for a tap, but I always remove it and replace the original steel cap once I have what I need.  Moisture in your fuel will cause a lot of grief.
Rod.
Offline Arlan McKee
« Reply #6 on: November 21, 2020, 09:58:55 PM »
What type of container do you have?
Offline Bootlegger
« Reply #7 on: November 22, 2020, 02:29:38 PM »
 arlan it is a metal container, and thanks for the suggestions fellows...      y1   H^^   D>K
Gil Causey
AMA# 6964
Offline Mike Danford
« Reply #8 on: November 23, 2020, 07:05:54 AM »
What about dispensing with CO2 like a keg?  Keeps air and moisture out, very precise, not nearly as expensive as spoiling a batch of fuel.
Tools
Offline Stephen
  • Stephen Hollier 217629
« Reply #9 on: November 23, 2020, 07:09:50 AM »
Hey Gil they make this tippers for 5 gallon containers.
Offline Bootlegger
« Reply #10 on: November 23, 2020, 10:45:37 AM »
Steve where can I find one? and thanks
Gil Causey
AMA# 6964
Offline Arlan McKee
« Reply #11 on: November 23, 2020, 12:36:12 PM »
A little pricey but the cheapest I've seen.  Would be easy enough to make something similar.
https://www.amazon.com/gp/aw/d/B083Y6HPQS/ref=sspa_mw_detail_2?ie=UTF8&psc=1
