  • July 08, 2025, 06:03:35 AM
Author Topic: suggestions for a build  (Read 4040 times)
Offline Rick Bollinger
  • AMA 931589
« on: August 16, 2013, 01:36:22 PM »
I flew beginner this year at the Nats and I am looking for a winter build. Here are the requirements. Full fuselage for a ro-jett 40 re. This is the bar stock engine. This will be my first full fuse build so would like to have it fairly a straight forward build. Something that is competitive up through advanced.
Rick
Rick Bollinger
AMA 931589
Offline Steve Fitton
Re: suggestions for a build
« Reply #1 on: August 16, 2013, 02:06:02 PM »
will the RoJett 40 be piped or non piped?
  • AMA 931589
« Reply #2 on: August 16, 2013, 02:12:58 PM »
can go ether way
Rick Bollinger
AMA 931589
« Reply #3 on: August 16, 2013, 02:34:53 PM »
Hi Rick,
I would say the Vector 40 is a simple build that is very competitive.  I would build the kit and not an ARF/ARC.
A better deal for me would be one of Randy Smith's ".40" piped models like the Satona, Staris, or Shrike.  These are about as good as it gets for the size engine you have with a pipe.
BIG Bear
RNMM/AMM
Offline Crist Rigotti
« Reply #4 on: August 16, 2013, 04:41:27 PM »
Rick,
Let me suggest a Legacy 40.  You can deepen the fuselage a bit for the pipe.  A great design and a great flyer.  The kit won't cost you $250 either.
« Reply #5 on: August 16, 2013, 04:52:18 PM »
What plane did you fly at the Nats?
Dwayne
« Reply #6 on: August 16, 2013, 04:54:39 PM »
If you really want to  get ambitious order from Brodak the plans and ribs from a Legacy or Vector and  bash it into something that's yours.  y1
« Reply #7 on: August 16, 2013, 06:51:39 PM »
The Beginner pattern to a built up fuse plane and a top of the line motor may be a bit of a big jump.
It might be prudent to consider a built up fuse plane using an LA-46, etc first.
Offline Will Davis
« Reply #8 on: August 16, 2013, 07:05:58 PM »
A cardinal kit or ARC with a la46 will teach you how to fly and be very competitive up to Advanced levels all most local contest,
If you must go with full fuselage , I would build a legacy 40
Will Davis
"Carolina Gang"
« Reply #9 on: August 16, 2013, 07:09:37 PM »
I agree completely with this advise! ^^^^^
Nothing against the Vector 40 or Legacy 40, but a model that is Classic Legit would let you fly two classes and that will make you competitive much quicker. Brodak and RSM both have some great choices, T-Birds, Tucker Special, Noblers, Olympics, Tucker Spl., Smoothie, Oriental, and did I mention...Tucker Special?  :) Steve
« Reply #10 on: August 16, 2013, 09:50:28 PM »
Rick,
 Exactly what I was going to suggest, in both the .40 size and the full size version the Legacy is an excellent airplane. A Legacy .40 with a Rojett could take you a long way. y1
  • AMA 931589
« Reply #11 on: August 16, 2013, 10:36:31 PM »
I flew a Stiletto with a Magnum 36 this year. I also have a smoothie, Nobler, Twister, Pathfinder along with some others. I was leaning towards the Vector because I could also get the arf's for practice planes. But looking in the shop I realized that I have stuff to practice with. What I need is something that I can compete with and would like to stay with the same plane for awhile. Also something that I built. I know that the second plane will build faster than the first and so on. That is why I am thinking of a more "top end" plane so that it would be easier and faster to duplicate when I crash. Not as often anymore but it does happen  HB~>. As for the Ro-Jett I got it to run it. If it turns out to be more than I can figure out I can always put in a magnum or a Fox 35  ;). Just kidding about the Fox but they are fun on my Ringmasters. But now it looks like a Legacy 40 may well be the ticket. And it is a beautiful plane. Who all kits the Legacy?
Thanks for the input and keep it coming.
Rick
Rick Bollinger
AMA 931589
« Reply #12 on: August 16, 2013, 10:43:34 PM »
If you really belong in Beginner then you'll be crashing -- so you want something that you can crash without tears.  That includes the engine, when you're flying over pavement.
I'd go with the Twister, or similar profile.  It'll fly way better than you, it'll be easy to repair, it'll be easy to trim, and if you completely smash it you won't cry.
Your Magnum 36 will be a good engine for it.
Offline Martin Quartim
    • StuntHobby
« Reply #13 on: August 16, 2013, 10:43:52 PM »
There is also the Oriental Plus RSM Kit for .40 tuned pipe engine.
From Plans there are many good choices. I  like my Pathfinder ARF from Brodak a lot and I asked John Miller to make plans for a Fullbody version, take a look:
http://www.cadclassics.net/pathfinder%20mk2fb.html
Randy Smith and Pat Johnston have some real nice plans too, you should check them out.
I can talk about the Pathfinder, which is the plane I learn the pattern and I still enjoy to fly today with good results.
There something magic about the Pathfinder wing, I can not make it to stall with full comand! I  can make some impressive small loopings with it.
Martin
  • AMA 931589
« Reply #14 on: August 16, 2013, 11:26:04 PM »
Here is a picture of my Stiletto. My twister I flew at Sig last year. I was very happy with the results and how it flew. But after flying the Stiletto it was like a Cadillac and a Chevette. I know which one fly's better and how it feels on the handle. That's what I am after.
Rick Bollinger
AMA 931589
Offline Noel Corney
« Reply #15 on: August 17, 2013, 12:21:15 AM »
Rick, You'r already flying a very good model in the Stilletto, Why not build another ?,They are a great model as you well know. Regards , Noel.
« Reply #16 on: August 17, 2013, 06:21:21 AM »
I think this is a great thought.  You are already used to the design and know how to build it.  You can add maybe 1/2" to the fuse bottom to accommodate a pipe , don't worry about totally enclosing it.  I leave mine partly exposed to help cooling.  I really like the RO Jett .40,  I have three.  I only suggest you take care not to put too much airplane on it.  In my mind it is about the most perfect 'classic' size stunt motor.  It's in a .25 case.  It's pulled up to 64  ounce airplanes pretty well for me but that was really too much.  Try for something 57 or less and the engine is happy.  I also found it worked well on a cheap APC 11-4.  The happy place for the engine with that prop was around 10,100 RPM.  That would be magnificent in a 55 ounce Stilletto.....
« Reply #17 on: August 17, 2013, 07:19:45 AM »
Rick,
Check your PM.
« Reply #18 on: August 17, 2013, 08:16:28 AM »
Look at all the planes in your stable.  You already have practice planes.   But, really you said it with the Stilleto, it is the plane you really like.   I know of some planes with well over several hundreds of flights on them.   Practice with the plane you are going to compete with.  If you can already do the beginner pattern you are only a few maneuvers from the full pattern.   As was told me when I first started flying the full pattern, it is only a series of loops and level laps.
  • AMA 931589
« Reply #19 on: August 17, 2013, 08:51:17 AM »
Thanks for all the replies. The Stiletto I did not build. It was given to me by Larry Lindberg. I don't know if the original is even being produced.
This one was scratch built with a Super chipmunk wing and Stiletto tips. I am thinking Legacy. The kit is just over 100.00 with plenty of support from SH and Brodak. Thanks Crist for the PM and hope to see you at the field in Oct.
Rick
Rick Bollinger
AMA 931589
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #20 on: August 17, 2013, 09:43:57 AM »
Rick: I would suggest the Buccaneer 740. This is also an Allen Brickhaus designed
plane. It's easy to build, looks good and flies great. My brother Doug and I have
both flown Buccaneer 740s and 746s and they are great planes. The Buc 740
was the first plane that Doug really learned to fly the pattern with and was able
to start improving. He flew the 740 and 746 for about three years in competition
and I firmly believe that his experience with these planes set him on the road to
becoming a National Champion.
Having flown both, I actually prefer the 740. It has 575 sq. in. of wing area and
would be a perfect match for your RO Jett 40.
« Reply #21 on: August 17, 2013, 11:43:12 AM »
Rick
The VECTOR 40 available from Brodak and Aero products would take you as far as you want to go, You could also use a kit, or a rib set and build the Tempest 40, SV-40, or DREADNOUGHT 40, these are straight forward easy designs and have won many NATs Championships all over the WORLD, as well as Here, and have been on Multi FAI World Champ teams.
Offline MarcusCordeiro
« Reply #22 on: August 17, 2013, 12:34:24 PM »
I'll add my 2 cents... Legacy 40 or Vector... ARF, pick the Vector, building a kit, pick the Legacy...
Me? Well, I'd pick both... LL~ LL~ ;) 8)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
  • AMA 931589
« Reply #23 on: August 17, 2013, 01:12:29 PM »
I think the Legacy 40. I will place the order Monday. Which tank? It shows the medium uniflow 4oz will this be enough for the Ro-Jett? I would like to order them together. And thanks to everyone who has helped.
Rick
Rick Bollinger
AMA 931589
« Reply #24 on: August 17, 2013, 03:41:47 PM »
Rick
Rick,
I think Allen used a 6 oz plastic R/C tank.  I think I did the same.  I'll send you the build article.
  • AMA 931589
« Reply #25 on: August 17, 2013, 07:56:09 PM »
Thanks, Crist
Rick Bollinger
AMA 931589
